My engine leaks with Castrol 20W50, so I'm really not too concerned about that, but I'm curious to see if there's any difference with the AMSOIL 20W50.
When bought my 84 it had been using M 1 5-30 , it had 171,000 plus at the time , no leaks, now at 191,600 still NO leaks !!!! (:
M 1 has gone up in price, thinking of changing to another synthetic oil, not sure which one , or would that be risky ?? cheers, Peter |
My 911 has a slight leak or two also, and I have always used Castrol 20W50. With 12 qts of oil, I don't like the thought of buying synthetic when I know my BMW has always run on the Castrol dino and is still going strong at 278,000 miles. I switched my recently acquired 110k mileage Audi back to synthetic because it has twin turbo chargers and was designed to run synthetic. A week after switching my wife started complaining of a burning smell when the car was sitting at stop lights. Sure enough my cam shaft seals are now leaking. :( Same holds true for a friend who swithed to synthetic is his high mileage '99 BMW 3 series. He called me to ask why he started smelling oil while sitting in traffic (he is not mechanically inclined so he calls me every time his car acts up). I asked if he might have left his oil cap loose or something and he said that he recently had the oil changed and was proud to tell me he just upgraded to synthetic. ;) I know it is not guaranteed to leak when making the switch on high mileage cars, but often it does. |
In my '89 Carrera 3.2 with 14,500 miles(!) I'm using Valvoline VR1 20W-50. PO's had used Kendal GTI 30W so for now I'm going with a multi-viscosity dino oil. I understand the VR1 has a higher level of ZDDP.
So far with 1,250 miles the only leak is the one that I had when I bought the car. Its the left side cam feed oil line. It leaking/seeping at the hose/fitting crimp. Its not really anything...I just wipe it up after a drive. I know I need to replace it. Other than that engine is clean and dry. So far at 1250 miles on oil I've not used any yet. I'll probably switch over to a synthetic at the next change. I want to get the quicker/better oil flow at start up that a synthetic would give. I use sythetics in all my other cars and bikes. I guess I've fallen somewhat for some of the folklore regarding our older air-cooled Porsches. David |
Tim,
I'm surprised to hear about the leak in your audi-and more surprised that you/ or PO wasn't using Syn on it to begin with? I belive that all the audi dealers out east anyway have used solely syn for a long time, and I thought that Audi has used only Syn as factor fill since the late 90's-and recommended that only syn be used (others such as BMW, Saab, Porsche have also done this for quite some time). For a turbo motor as well, syn is your best bet. |
I see people making comments about leaks switching from one to another but after exhaustive search I have yet to actually see any post with a user here or on the other boards that have actually suffered from this.
So for me its total BS especially since we have no users that can directly say yes it happened to me and yes it was the cause. I switched mine after 90k of using dino oil to a pure synthetic "royal purple" NO leaks at all. DONT believe the hype or hear-say friend of a friend BS. Try Royal Purple or Silkolene they stand up well................. As for that matter I very rarely see any engine kabooms that can be directly related to the type of oil but the delivery or mechanical health |
I can say I directly experienced leaks after switching to synthetic. The GF's old 924S started leaking internally into the coolant system at the oil cooler within a week of switching...she had the oil changed by a local mechanic who told her how much better it is for the car. Maybe it was a coincidence...
Pat |
yeah I can agree the syn will clean out an engine.
I know others disagree, and I hear the stories, but I have never experienced a leak as a result of switching from dino to synth (M1 15/50, AMSOIL 10/40, and AMSOIL 20/50) This includes 3 911's ranging from 60k miles to well over 100k at the time of the switch, my recent 930 with 33,500 miles, a Land Rover ( they leak when empty!) various BMW's, Jeeps, and my wifes LX450. Even my lawn mower!!!! I guess I've been lucky, but this is my experience.
Now they'll all leak tomorrow!!! I think the advantage is worth the chance.... tim. |
it all depends how good of shape the seals are in and climate
Efhughes 3.....I'm a dino user also. Maybe we should have our own string?
I've had an '88 3.2 for about 14 months. PO's used either Castrol, not my pref or Chev Delo....I've had three oil changes in the past 10k with Pennzoil multigrade (10-40), no leaks to speak of either before or after. Been using about 1 qt per 3k oil change. Been following various oil strings and just bought a case of Brad Penn from Navarro. Oil change next week and will see how it looks. More interested in wear factors as mentioned previous strings. |
M1 15W50 - its a good oil
Petrolblue, I was suprised also! After buying the car, with about 100k on the clock, I started fixing a few items. The PO had just recently had the oil changed and I did not give it a second thought, but later I found a few receipts in the glove box from a small town oil service place and it listed Quaker State dino oil! :eek: I knew about Audi's stringent oil specs (I spent a small fortune on their special synthetic power steering fluid and automatic transmission fluid already ;) ). Anyhow it did indeed start leaking after I switched to synthetic and in the next month or so, I will be yanking the front bumper and radiator, pulling the timing belt so that I can reseal the front of the engine. I found a nice kit with new timing belt hardware, water pump, Audi coolant and front seals for around $300. The bummer is that the timing belt had been changed at 80k and was not due yet, but no way am I pulling all this apart w/out changing the belt and water pump as it is all a PITA to get to on the Audi. Hey loaded, I am happy you have not had any leaks due to switching to synthetic on HIGH MILEAGE cars. I HAVE and I know others who have also. I am not making this up and all said, I guess I really don't care ultimately whether others suffer this problem. I knew it might happen when I switched my high mileage Audi, but it needed to be done IMO, with the twin turbo's and all. I am 100% confident that my 911 does not NEED to eat synthetic though so I choose to stay with dino in that car. I can't say that I know of any 911 owners who have suffered a problem, but I know of BMW's and obviously an Audi that suffered the problem. Many 911's have a few leaks to start with, so that might tend to mask the situation, or maybe the seal design on the aircooled cars is a bit more tolerant of the switch. |
| All times are GMT -8. The time now is 03:21 PM. |
