Broken fuel door won't open...
Last night when I went to refuel my 1981 911sc euro tubro look ZZZ Porsche the fuel door release broke and now I can not get in to refuel.......How do I get in? Any suggestions short of dismanteling the port side.
Take a length of dental floss...maybe even double it up...and stretch it across the filler flap facing the rear of the flap...get it to "hook under" the door ...and tug "forward" with one hand on each side of the filler door. It should "catch" the release lever-arm and allow you to open the door.
Report back if it works.... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Dental floss breaks (BTDT). Carry a soft flat cotton shoestring in your toolkit.
Brian |
If the wire broke, then you can grab it with some needle nose pliers, just pull the wire housing out of the way.
If that doesn't work, then there is a allen bolt that holds the latch on. Look on the hinge post of the driver's side door, inside a small round hole. Loosen the bolt, and the latch should come off. Jiggle the lid a little and it should open. |
Go in the fenderwell and release 3 allen bolts. You might have to brush a little mud off them. When the bolts are out, start working it up at the hinge. Go easy, don't pry or chip.
Amazing! It took me longer to find an old tennis shoe with a flat lace than it did to open the fuel door. Brians idea of using the flat shoe lace and Wil's directions on the use of the shoe lace worked without a hitch. I,m sure that the floss or similar would also work. The shoe lace is now under the bonnett. This was my first visit to this forum or any forum........what a great experence. Thanks to all for your concern.
3.4 Bigger is better
Conover,
Welcome to the forum and the slippery slope that it starts ![]() Pictures of your car are always welcome on the board.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
I carry an eight-inch length of strong nylon string with finger-loops on each end, in the glovebox. I've never had to use it, but it's there...
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
This is great. I'm putting a shoelace in the glove compartment today.
![]() Brian |
Curious - Since the number of times a filler door is opened correlates with total chassis mileage -- What is the mileage one can expect their filler door to 'malfunction'? Is it always a matter of the cable (wire actually) breaking?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
Brian |
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Gon fix it with me hammer
nylon string ?!? just get a screw driver in between , push the little mechanisme and done, do dent the paint while you're in there.... or are y'all in to concourse or sometin???
sheesh ![]()
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Why would you chip your paint and dent the bodywork....well, ever? ...especially if all it takes is a little piee of string to address this little problem?
Dan in Pasadena '76 911S Sahara Beige/Cork |
1984 Targa |
Hey, he's a tough guy. Sheesh.
ok, I'll pile on...
there is no 'e' in councours (there is also no me in concours, but that is a different question)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 09-30-2006 at 09:03 PM.. |
I've used a kitchen butter knife (thinner than a screwdriver, so no paint chips). I stlll carry it in my tool kit.
1981 911SC Euro Trial & error, mostly error, I'll figure it out. |
