wheatdog's Avatar
Front Oil Cooler Screen???
Just finished the front oil cooler install for my 3.6 engine swap. Where does one find a suitable wire screen material for mounting over the cooler to protect the core from road debris imact?
Mike
Old 07-02-2005, 07:14 AM
I got mine--stainless steel wire mesh--from Pegasus Auto Racing Supplies, and I find it very handsome and effective. They sell three or four different densities. I bought the coarsest.
stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-02-2005, 09:13 AM
I got the medium mesh, also from Pegasus.
Stay with stainless steel. Hardware store mesh is usually galvanized steel or aluminum. A well-placed stone will bend that material w/o trying.
Sherwood
Old 07-02-2005, 02:19 PM
I have seen pics of the rear decklid grill trimed to fit. Looks rear sharp and might be a good solution.
Matt West
1980 911 SC
Old 07-03-2005, 06:50 AM
wheatdog's Avatar
Thanks Gents,
I'll order right away cause once this beast is running there's no way I can just let it sit in the driveway waiting on the screen. Hope I don't hit too much junk before the screen arrives.
Mike
The cars been down for almost 4 mos and I've got a serious
Porsche jones going.
Old 07-03-2005, 07:19 AM
Super Moderator
cstreit's Avatar
I used "stretched metal" on mine. It's more solid than wire mesh and keeps out smaller rocks.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-03-2005, 07:27 AM
McMaster Carr carries a bunch of different sized perforated metals.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-03-2005, 06:30 PM
Before using a perforated sheet, I'd suggest getting the specs on the desired pattern. Manufacturers should have airflow % specs for each pattern and pattern dimension. If not, get some sample sheets. hold each outside a moving car window and see how much air goes through.
Perforated metals are more like sheet metal with holes pierced in them. It depends on the pattern, but welded or woven wire mesh generally has a larger area for airflow and a smaller cross section of metal.
Woven wire
Perforated metal
Expanded metal
In addition, stainless steel is much more rigid in any comparable dimension compared with aluminum or galvanized steel. The objective is more air; less foreign object penetration to protect the heat exchangers (oil cooler, intercooler and/or coolant radiators).
Sherwood
Old 07-03-2005, 08:43 PM
Woven wire
Perforated metal
Expanded metal
In addition, stainless steel is much more rigid in any comparable dimension compared with aluminum or galvanized steel. The objective is more air; less foreign object penetration to protect the heat exchangers (oil cooler, intercooler, coolant radiators).
Sherwood
