PAT4's Avatar
Rear toe problem
my 911 T runs now beautifully and I drove about 200 kms this week-end but I noticed that the car goes to the left if I let go the steering wheel.
So I bring the car at the mechanic this morning for a basic alignment and he just called me to say that front alignment was perfect but there was a problem on the rear passenger wheel that has +2° TOE instead of 0 to -1.5° factory settings. The problem is that the adjustment screw is at the stop and he cannot reduce the TOE.
He told me about enlarging the adjustment hole, but I do not like that solution. My idea is about Rear Spring Plate and Trailing Arm Bushings. Do you think that they can do that if they fail ?
Regards,
Old 07-04-2005, 05:18 AM
Used Up User
imcarthur's Avatar
Trailing arm bushings - maybe. How about the trailing arm itself - does it look alright? Is your springplate straight? Is the toe eccentric bolt in good shape & doing it's job?
Ian
'87 Carrera Cab
Old 07-04-2005, 06:48 AM
PAT4's Avatar
No visual problem ..
Old 07-04-2005, 08:43 AM
Southern Class & Sass
Dixie's Avatar
Is the car lowered?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 07-04-2005, 08:47 AM
PAT4's Avatar
Front lowered, yes. 64 cm at wheel arch top with 195/65x15 tires
Rear, I think no. 63cm at wheel arch top with 205/60x15 tires
Old 07-04-2005, 08:57 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Be sure the hubs are straight, too.
edit for correction:
I was thinking of the wrong problem. A bent hub should result in a pulsing brake pedal, not necessarily misalignment. This problem is interesting, though, because the bushings shouldn't account for so much deviation. I wonder about the accuracy of the measurements taken by the mechanic. Also, do the tires show wear that is consistent with severe toe?
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-04-2005, 10:58 AM
