Me like track days
Craig 930 RS's Avatar
Exclamation * H4 headlight took OFF on right turn, need screw
The left H4 headlight departed the 911 yesterday.
Went for a fun run, exited the freeway, took a hard right, and off pops the headlight.
ClAnK, ting ting t-ting, scraaaaape...., launching onto the streets of Bellevue WA. So I hung a left and swooped in to grab the unit. Scratched lens, dented trim ring, crap.
*Is there any way to better secure these H4s to our 911s?*
BTW, that special screw is now adios.
Anyone have one to sell, ASAP?
Signed,
One-Eyed in Kirkland
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-08-2005, 09:47 AM
I agree...the mounting sucks....
Maybe the top "lip" over which these hang (..to be pushed against the bottom using a screw)...can be made larger and more "meaty" ???
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-08-2005, 09:53 AM
Chuck Moreland's Avatar
I have H1s and they pop off easily. I use a couple zip ties loosely attaching the adjuster mechanism to the fender. That way if it pops, at least it stays on the car.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-08-2005, 10:21 AM
i ran over one of my H1s on a test drive. sucks. forgot i just layed it in there to check the fit.
206 637 4071
Old 04-08-2005, 10:36 AM
I do have some screws for the non over lay style ones.. None for the ones with trim rings though..
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-08-2005, 10:38 AM
Administrator
Jack Olsen's Avatar
Everybody should do this:
I think I have one of the fasteners you need, but I don't have the insert screw (although I'd guess that's the easy part). Is this it?
Old 04-08-2005, 10:58 AM
Oh Haha's Avatar
Hey Jack, what is the Porsche part number for that plastic retaining device?
Do these really pop out that easily? You would think that the engineers would have fixed that little problem.
Pacific Blue
Wayne
Old 04-08-2005, 12:10 PM
Ya..and you woulda' thought they woulda put FUSES where they'd be required, too ....hah !
Wil
Wil Ferch
Old 04-08-2005, 12:13 PM
Administrator
Jack Olsen's Avatar
Ironically, I lost two headlights this way -- before I went to fiberglass fenders. In my opinion, it's a design flaw.
Old 04-08-2005, 12:54 PM
Senior Member
Superman's Avatar
I probably need a screw too, but I don't see an image here of the type of screw I need. I don't think Wayne allows those images here.
Mocha 1978 911SC. "Coco"
Old 04-08-2005, 12:59 PM
Me like track days
My screw did look different, Jack - but it is indeed the one that attaches the light to the bottom of the bucket. Do one of ya'll have one I can buy?
Great tip about securing the headlight to the car!
THX
Old 04-08-2005, 01:06 PM
Carl83911's Avatar
Re: * H4 headlight took OFF on right turn, need screw
Signed,
____
I just installed a pair. I find is hard to believe that your popped out like that. If the bottom screw is on tight, it shouldn't pop off. did the bolt to chasis break off or something? I have a couple of extra screws. Did you also use the trim ring with the inner screw that fits into the bottom screw that's anchored to the bucket? Send me an e-mail w/ you address or p.o. box. I'll give you my extra ones.
Old 04-08-2005, 01:53 PM
Noel's Avatar
Signed,
If you are referring to the trim ring screw at the bottom of the headlight assembly, then I have an extra one that you can have. Part# 911-631-146-01 Listed as trim ring screw (1974-1986). It works with my 1980 stock sealed beam lights. I'll attach a photo below. PM me you address and I'll drop it in the mail on Sat.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 04-08-2005, 02:32 PM
Carl 83911:
Even so...the top is connected by placing the top ring of the headlight assembly over a much-too-small "lip" of the car's headlight bucket....that if you lose grip there...allows everything to "fly" ....
- Wil
Wil Ferch
Old 04-08-2005, 02:33 PM
Carl83911's Avatar
Originally posted by Wil Ferch
Carl 83911:
- Wil
____
Yes, I'm aware of the top lip. But if the bottom screw is tightly screwed into the anchor attached to the bucket, it shouldn't fly off (depending i guess on how fast you're driving at the time). I can expect some kind of rattle or something. Was the screw stripped?
Old 04-08-2005, 02:36 PM
Noel's Avatar
Here it is:
Old 04-08-2005, 02:38 PM
Me like track days
The screw must have stripped from the force of the unit hopping off -
Carl, thanks for the screws! You have a PM
Old 04-08-2005, 03:35 PM
I lost one H1 while delivering my 911T to a new owner in AZ. Driving across the desert, stop to take a leak. Come out and there I am staring at blinky....There is a nice H1 sitting out in the desert between LA and Phoenix somewhere...
Mike
'77 911 3.0
'94 Mustang GT
'77 911 (soon be a real live racecar!)
Old 04-09-2005, 12:41 AM
The beauty of the original headlight design was only skin deep.
One up for the Sugar scoops
Old 04-09-2005, 01:31 AM
Carl83911's Avatar
____
Craig, Got your PM. I tried to send you a response but it a message said that It cannot send my reply due to your mailbox being full.
I'll be sending you the screws either today 4/12/05 or tomorrow. it shouldn't take too long for you to receive them.
Old 04-12-2005, 09:34 AM
