Vintage race car color
Does anyone know for sure the color of white used on all the vintage era Porsche race cars. 906,908,917, 911R. I believe it was light ivory #6604 but I'd appreciate confirmation. I want to make sure my porject gets the right color. Thanks in advance.
Old 07-01-2005, 08:51 PM
cnielsen's Avatar
I think the color code was 111. That is what the 911R's were so I assume the other race cars were the same.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 07-02-2005, 06:12 AM
Do you know the name of the color? I'm trying to find the code on line right now. Thanks
Old 07-02-2005, 09:20 AM
Nobody
bob tilton's Avatar
i would contact richard on the early s reg. he just had his car painted and i believe he told me that there is a ford color (straight color-no mix) that matches perfect. if you need me to put you in touch with him then just PM me.
Bob Tilton
www.werkcrew.com
Old 07-02-2005, 09:46 AM
Bob ,That would be great sent you a PM. Thanks Robert
Old 07-02-2005, 10:56 AM
911R color, light ivory
Of the 20 series 911R's built, 18 were light Ivory, 2 were special order colors, one blue, and one gold. color code for light ivory in model year 67/68 is 6804.
Ernie Wilberg
R-Gruppe Techmeister
1967 911S
40 year member PCA
http://www.pbase.com/911r
Old 07-02-2005, 11:00 AM
Ernie, This is where I'm running into a conflict. Everything I find says color code for 65-68 Light Ivory is # 6604. I know that is the color but the code is what's not clear. Thanks RK
Old 07-02-2005, 11:04 AM
color coding
The two figures 66 denote the 1966 color range.
The figures 01-09 are standard production colors in the range concerned.
slate gray 6601
polo red 6602
gulf blue 6603
light ivory 6604
bahama yellow 6605
irish green 6606
sand beige 6607
aga blue 6608
black 6609 plus 22 special colors.
The 911R was a 1968 model, thus the color code for light ivory in 1968 is 6804
Ernie Wilberg
1967 911S
40 year member PCA
Old 07-02-2005, 08:55 PM
Ernie, I've learned something new. Great information and finally an answer to my question. Light Ivory it is. Thanks
Old 07-02-2005, 08:59 PM
Light Ivory color
I recently repainted my '67S back to it's original Light Ivory color. It turned out to be a bit of a challenge to get the color right but in the end I found an easy solution I'll decribe at the end of this note. First, keep in mind that there is both a color "number" and a color "code". The color code for light ivory is 131. But that won't get you the correct color. You'll need to use the color number. For light ivory that number changed over the early years. For 1965 it's 6404; for 1966-67 it's 6604; for 1968-69 it's 6806; for 1970-73 it's 1110 for Targas and 1111 for coupes. The color code remained 131 throughout these years. The plate showing the paint code number is located on the left door hinge post. The painter I worked with, Freddie Hernandez, prefers to use PPG two stage paint. (Base coat/clear coat) rather than the original German paint. The paint shop was unable to find the paint number (6604) so we started trying to match old paint from parts off my car and friends' cars. The match wasn't looking right. Finally we tried paint number 1111 - light ivory for a '73 coupe, and bingo...we got a perfect match. It turns out it's now a Ford color with the code "DBC8321" - "Ford White". It turned out beautifully and is an almost perfect match to a friends original paint light ivory '67S. If you're not hung up on using the original German paint I suggest using this PPG color. I don't think you'll be disappointed. Good luck,
Richard
Old 07-03-2005, 01:35 PM
Smile
That is more great infomation. I appreciate helping me get my car right. Thanks again!
Old 07-03-2005, 01:40 PM
