Pkaaso's Avatar
Vibration at 1600rpm
Has anyone experienced this? What to check first?
74' 911 2.7
Right at 1600rpm on normal take-off, I get a vibration/rumble from the rear. If I take off in traffic, low rpm and after clutch is engaged, I can feel/hear it.
It just started, doesn't seem to be getting worse. The only mods have been short shift kit.
Am I just now noticing something that has always been there? Am I launching too low RPM's???
Thanks,
???paul???
If you aint breakin' it, you aint racing it hard enough!
1974 911 3.0 Euro Sahara Beige/Black
Old 07-03-2005, 03:07 PM
fred cook's Avatar
Cool Low RPM Vibration.....
If your car still has one of the rubber center clutch discs, a chunk of rubber might have come out and gotten lodged on one side of the pressure plate. I had this happen on a 1988 924S. The fix is a new clutch.
Good Luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-03-2005, 03:24 PM
Pkaaso's Avatar
I did replace the disk with a spring type when I had the engine out last time.
Thanks,
Paul
Old 07-03-2005, 03:35 PM
Non Compos Mentis
Keep it above 1600 rpm. Way above.
Old 07-03-2005, 03:44 PM
450knotOffice's Avatar
Paul, get John over for a test drive...
Did you get those tires yet?
Old 07-03-2005, 03:52 PM
Pkaaso's Avatar
Scott,
I'll have to get him to drive it to get his oppinion. I just don't remember that vibration being there before. But, I always took off at about 2500 to 3000 rpm. It' just when my daughter is riding with me, I like to really take it easy. I know, I know... These cars arn't meant to be taken easy.
No, tires are ordered but not mounted yet. I have been struggleing with the idea of having the rims polished by AL REED first. But then, I've been told that is not the best idea as the polish is only good for about a year or so. I think I will have the rims cleaned and repainted back to stock.
What do you think?
Paul
Old 07-03-2005, 10:56 PM
Pkaaso's Avatar
By-the-way
What is the best rpm to take off at? Under normal traffic conditions?
Too high... wearing clutch
Too low... lugging engine
What to do to die today?
Old 07-03-2005, 10:58 PM
Pkaaso's Avatar
Prolly go with the Toyo Proxes 4 these are replacing the FZ-4
Good price and seems to be a good tire.
Old 07-03-2005, 11:01 PM
bigchillcar's Avatar
i notice this same shudder when i'm backing out of my driveway..i just release the clutch while under very little power and i often feel a shudder. sounds like the same thing..just the clutch slipping a little maybe.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 07-03-2005, 11:06 PM
Gon fix it with me hammer
svandamme's Avatar
chain tensioners ok ?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-04-2005, 02:54 AM
I use about 1,400 to 1,500 or so and tend to get a little shudder from the clutch but the car comes off of a dead stop easily that way. Doesn't seem to be a big deal.
Old 07-04-2005, 12:58 PM
Pkaaso's Avatar
I'm off the clutch completely by the time I feel the vib/rumble.
Still not sure what I'm feeling/hearing.
Chain tensioners are rebuilt and added the collar.
Paul
Old 07-04-2005, 03:00 PM
paul,
hmm..have you checked your motor mounts lately?
ryan
Old 07-04-2005, 03:08 PM
Pkaaso's Avatar
Ryan
No, I have not. I'll look at those tomorrow.
Thanks,
Paul
Old 07-04-2005, 04:21 PM
Pkaaso's Avatar
Maybe I'll just replace everything connected to the gas cap.
Old 07-04-2005, 04:22 PM
