				settling suspention duringcorner balance
			Hi all are there any tricks for getting the suspension to settle
				during adjustment? I have been standing on the cage door bars but I still get a change if I drive the car. My bushings are needle bearings and bronze bushings and my sway bars are disconnected. Its a pain to drive the car then put it back on the scales.I lost a inch of rear ride hight last week after 2 track days from my original setup.I removed tbars today checked bushings and bars all OK no binding. Any help would be great Thanks Palmer  |
			I use pieces of 1/4" plastic (white - I think it's polystyrene) with a slight bit of oil between them to allow the wheels to slide outward.  This helps, but I still get slight differences between iterations, and I have polybronze and monoballs all the way around.
	"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs  |
