Recreational User
porschenut's Avatar
Track tire wear
Generally, which will wear out faster - fronts or rears? Tires are track-only V700 Victoracers.
Old 07-30-2005, 09:09 PM
Lots of variables here from driving style, to HP, to chassis setup, to car weight. FWIW, victoracers on my 993 wore pretty evenly f-r, with perhaps a bit greater wear on the rears.
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 07-30-2005, 10:05 PM
As Edward said, car & driver are the biggest variables.
On my 930, my F/R wears are about the same. On my buddy's 934.5, his ratio is 2 sets of rear to 1 set of fronts. Another friend's 3.2 has more wear in the rear.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 07-31-2005, 03:49 AM
abit off center
cgarr's Avatar
Even on my low power/low weight 912 the rears get a tad more wear than the fronts, and thats both autox and high speed tracks (hummm high speed + 912 = Oxymoron)
Craig
______________________
Craig
G2Performance
Old 07-31-2005, 04:04 AM
On the track in my '87, I go through 2 sets of rear tires for every set of fronts. This is with VictoRacers (225/50 16 and 245/45 16) or RA1s (235/45 17 and 255/40 17). Car is not exactly overpowered (engine is stock except for no cat), but my driving style does involve quite a bit of throttle steering.
Mike
'87 911
Old 07-31-2005, 04:22 AM
Todd Simpson's Avatar
I'm about 2 rears for every front with A032R's.
Guys running similar cars with Pilot Sport Cups get about the same front and rear, with a little less life from the front.
Old 07-31-2005, 04:28 AM
Rears, no question. If your adding camber, even quicker.
Old 07-31-2005, 05:25 AM
jacko241's Avatar
On my SCCA GT-2 911, I use 2 sets of rear 12x25.5x16 Goodyear slicks to one set of front 10.5x23.5x16s.
Joe
996 GT3 RSR
Old 07-31-2005, 10:34 AM
Automotive Monomaniac
Emission's Avatar
Same here.
It depends a lot on the driver and track too.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 07-31-2005, 11:03 AM
Recreational User
porschenut's Avatar
Thanks for all the responses. I was pretty sure my rears would wear out before the fronts, and I'm convinced they will. The reason I asked has to do with longer drives to DE events. For treks up to 2 hours, I'm willing to keep 2 of the track tires on the car while 2 ride on a roof rack, and I wanted to determine which set gets to ride "al fresco". My goal is for all 4 tires to reach their wear limits at the same time, so I'll put the rears on the rack and use my streets in their place. For the really long drives, all 4 will ride up top.
Old 07-31-2005, 02:34 PM
