RBS RBS is offline
Question Parking Brake Light Stays On
New Porsche owner here, (’87 Targa), and I am starting on my list of things to fix. Today I removed parts of the car phone including the holder that was mounted just behind the Automatic Heating Control and the Parking Brake Lever. I used little plastic rivets/plugs to fill the screw holes. The problem is now the parking brake warning light on the dash is on even if the brake lever is down. I must have messed up the parking brake sensor or switch. How do I get access to that sensor or switch, and how do I adjust it?
TIA
Rob
Old 07-03-2005, 07:38 PM
project 911's Avatar
Rob-
I'm not shure if your is the same as my 71, but on mine I had to lift the rubber boot and find a screw head located at the rear of the brake handle unit. I think it has a slot that allows the screw to slide. You are supposed to pull the handle up one click, then adjust that screw until the dash light just comes on.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 07-04-2005, 06:07 AM
