915 (923/02) from 76 912e w/ 7:31
Anybody know the difference with the 915 from 76-86 from above
subject?Will it fit 76-86 911's?
tia
Old 07-05-2005, 03:46 PM
NO Will not fit, the input shaft has a different spline for the 4 cyl 912 motor.
Good parts source for a 915 though.
Regards
Hayden
Old 07-05-2005, 05:25 PM
915(923/02) 76 912e w/ 7:31
Thanks for the reply Hayden (wevoid),
One more ? pls. If you change the input shaft to a 911- 915 ,
will it work?
thanks again
ra
Old 07-05-2005, 06:17 PM
Yes, a 923/02 with a 911 input shaft will work with the 6 cylinder motor. You should also consider the clutch cable / release fork configuration - which is different to a 915 - and the actual ratios of the 923/02 as these might or might not suit the intended 6 cylinder use.
Regards
Hayden
Old 07-06-2005, 09:31 AM
