Kevin Stewart's Avatar
sc oil tank check valve???????
On the sc oil tank, i know when you over fill them the motor smokes, is there some kind of valve or something that should go in the vent lines,
anyone have any photos of the vent hoses, Kevin
Old 07-03-2005, 01:55 PM
tholyoak's Avatar
Kevin,
For your 3.6 conversion you need to restrict the opening of the oil tank line to the intake boot. This was done by the factory by using a cone shaped brass insert that reduces the diameter to ~1/2". There are lots of ways to do this, another benefit is the car won't die when running and the oli cap is removed to check the oil.
Todd
1989 911 Targa
Old 07-03-2005, 04:25 PM
tholyoak's Avatar
Kevin,
Here is a pic of the factory restrictor used on 3.2L. As I said anything you can dream up to restrict the size down will work.
Todd
1989 911 Targa
Old 07-04-2005, 07:25 AM
tholyoak, do you have a part number, Kevin
Old 07-04-2005, 10:35 AM
RETIRED
Joe Bob's Avatar
Didn't they also use a brillo pad type of thingy as well?
2012 ML350 3.0 Turbo Diesel
Old 07-04-2005, 10:46 AM
tholyoak's Avatar
Kevin,
Part # 930 107 289 00. Not sure about the brillo pad thing, but some of the SC's used a part called a flame arrestor that looked like a round cheese grater.
Todd
1989 911 Targa
Old 07-04-2005, 11:09 AM
I am sure this is why my motor is sucking oil, Kevin
Old 07-04-2005, 11:11 AM
tholyoak's Avatar
Kevin,
If you think it is your problem, disconnect the line from the oil tank and plug the line and the open port on the tank and see if this fixes your problem. Personally I would highly doubt that this is the root of the problem. But then again I may be wrong.
Todd
1989 911 Targa
Old 07-04-2005, 11:24 AM
i think it may be a combination sitting and over full a little on the oil, i know something is supposed to be in the line, I have just never figured out what, Kevin
Old 07-04-2005, 12:35 PM
