-   -   I need to run new fuel line through the tunnel. What should I use? (http://forums.pelicanparts.com/porsche-911-technical-forum/229519-i-need-run-new-fuel-line-through-tunnel-what-should-i-use.html)
rennch 07-05-2005 06:08 AM
Hi,
I've got a 69T and a 79 3.0 SC engine. My fuel pump is located up front...what's the best fuel line to run from the back of the car through the tunnel? And any tips running it through? I know it's a PITA, but I don't want to make my life any more difficult by running the wrong stuff.
Thanks,
mto
armandodiaz 07-05-2005 07:43 AM
I'm going to be doing the same soon. I'm installing a fuel cell in my Carrera. I'm planning on using 3/8" aluminum flex. But I'd be interested in other's opinions.
zymurgist 07-05-2005 08:22 AM
I'm going to do this on a 914 real soon now, and I'm planning on bending mild steel lines to fit. Not exactly the same thing as a 911, but close.
chrisp 07-05-2005 08:29 AM
Why not use OEM SC lines? I replaced mine this past spring and although it's a bit of a challenge it would have been that much more difficult to measure/cut/add fittings, etc than just bolting up new OEM lines.
Not sure if the SWB/LWB thing will have an impact.
rennch 07-05-2005 08:33 AM
Well...Dave from Dart Auto in Denver ran this plastic line through the tunnel for my other car...and I had no problems with it. I was just curious if I could get something from the local Checker and run with that.
