gtc gtc is offline
abides.
gtc's Avatar
Frequently burning out 100w H1 bulbs
I am running 100w high and low bulbs in my left H1 headlamp. The lowbeam bulb blows relatively often, at least every other month. Is this a common symptom of running high wattage bulbs? I know that high watt bulbs have a considerably shorter lifespan than normal 65w bulbs, but this seems excessive. It's getting to a point where I'm considering replacing it with an H4.
FWIW, I do have the relay kit installed, and I am using a Euro H4 on the right side of the car, but I can't see why these would have an effect on bulb life.
Thanks,
Graham
1984 Carrera Targa
Old 12-07-2009, 04:57 PM
boxster03's Avatar
wow at 100 bucks a bulb you could make the pmt on a new 911 ea month instead of replacing bulbs. maybe just drive it in the day
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 12-07-2009, 05:49 PM
Make sure you do not touch the glass of the bulb - the oil on your fingers can cause them to burn out.
Old 12-07-2009, 05:52 PM
I've had illegal 130-watt H4s for five years now with no problem.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-07-2009, 05:54 PM
only thing I can think of, touching the bulb
1973 911S (since new) RS MFI specs
1991 C2 Turbo
David's Avatar
How do you guys run these on the streets? I used to run 55/100 bulbs on my motorcycle and the high beam was like a laser. Occasionally a car would flash me on low beam so I'd flash the 100W highbeam and they would limp away quietly.
Old 12-07-2009, 06:05 PM
Diss Member
Quicksilver's Avatar
I'm wondering if the connectors on your H1s are generating heat. Is the connector very firm to connect and uncolored by heat?
I bend the female contacts on my cars so they have extra preload and make sure they are very clean and then use dielectric grease to seal them from the elements. On the cars that I use hi wattage bulbs on I always use a relay with a 12 gauge or better wire. As to the mention of finger prints: I clean the bulbs with alcohol before I insert them and I make sure the inside of the lights remain clean and dry.
As for the wattage in the 911: I run 80/100 "all weather" bulbs that have a slightly yellow tint. It fools the eye into thinking it isn't overly bright.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-07-2009, 06:14 PM
DUK DUK is offline
DUK's Avatar
Is your voltage regulator going bad and sending voltage spikes to them? Just a thought.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 12-07-2009, 06:28 PM
Make sure your charging system is operating correctly. A small change in voltage has a drastic effect on auto lamp life. A 5% increase in voltage, so about 0.5V in a car, will typically decrease life by about 40%. A 100W lamp, which already has a reduced life, would be the first to go. It is also true that a 5% reduction in voltage willl give a 40% increase in life but of course with reduced output.
Chuck
'96 993 C2 coupe
'87 Carrera coupe - gone but not forgotten
many lesser vehicles
Old 12-07-2009, 06:31 PM
Automotive Monomaniac
Emission's Avatar
I'm running H4 80/100W bulbs with the relay. I got about 20,000 miles/7 years out of them before one low beam gave out. No worries as the replacement bulbs are only $7.05 each.
I'm betting oil (from your hands?) or moisture is getting on the bulb somehow.
- Mike
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 12-07-2009, 06:59 PM
Good suggestions here,......
Make certain that the brown ground wires are clean and tight. Any loose crimps, spade connectors raise the resistane and lower the voltage, something that halogen bulbs (especially high-wattage ones) do not like and will drastically shorten their lifespan.
I'd also "second" the suggestion about installing larger guage wires and relays. That really improves voltage at the lamp.
Properly installed, these bulbs (not the Korean or Chinese ones) last a long time. My DD has 100/150w H4's that have been in service since 1992.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-07-2009, 07:20 PM
Happiest when Tinkering
gsmith660's Avatar
I have had the 100/100 watt H-1 bulbs in my car for > 10 years. 100 bucks a bulb now WOW! Just looked at the bulbs how about 10 bucks a bulb.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-07-2009, 07:30 PM
gsmith660's Avatar
I have my high output bulbs on a relay setup that pulls the 12 volts straight off the battery but I did notice that the relays get a little warm when running the lights.
Old 12-07-2009, 07:37 PM
gtc gtc is offline
abides.
gtc's Avatar
Thank you for all the responses. Based on these suggestions, I am thinking the bulb and harness connectors may be the culprit. They are all snug, but I suppose there might be a bit of corrosion inside that I am not seeing. I am always very careful to avoid touching the glass, so I am certain that is not the issue.
Fortunately, the bulbs are ~$6.50 through pelican, not $100. What's most irritating is that my FLAPS' don't carry high-output bulbs.
It is really a shame that the H1 housings aren't made any more. The output and adjustability is so much nicer than the [basically fixed] H4.
Graham
1984 Carrera Targa
Old 12-08-2009, 02:15 PM
Senior Member
Superman's Avatar
I'm curious as to whether super-skookum plugs can be found, and how much they help. Steve?
I've run 55/100's for years with relays and have not had trouble, but before I go to wattages higher than 100, I intend to upgrade the conductors.
Mocha 1978 911SC. "Coco"
Old 12-08-2009, 02:21 PM
gtc gtc is offline
abides.
gtc's Avatar
There are supposedly ceramic high-temp headlamp connectors, but I have yet to find them locally.
And before everyone screams "Daniel Stern" in unison, yes, I know...
Graham
1984 Carrera Targa
Old 12-08-2009, 02:27 PM
dshepp806's Avatar
+1 on that upgrade!!!!!!!
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-08-2009, 02:50 PM
"It is really a shame that the H1 housings aren't made any more. The output and adjustability is so much nicer than the [basically fixed] H4."
Why do you say that? H4s are fully adjustable both horizontally and vertically.
"I'm curious as to whether super-skookum plugs can be found, and how much they help. Steve?"
I don't remember where I got my 130s five or six years ago. A week or two ago I was looking for a backup set to keep on the shelf, and I couldn't find anything stronger than "off road" 100s. Do they make a difference? I have no idea, having never driven my SC with anything else, but they seem to be at least on a par with excellent current-model lighting--maybe not some over-the-top BMW super-Xenon but everything else. And yes, I installed very heavy-gauge wiring and dual relays.
Stephan Wilkinson
Old 12-08-2009, 03:05 PM
Formerly known as Syzygy
Canada Kev's Avatar
I think those "super skookum plugs" mentioned before were not the bulbs, but rather the sockets for the bulb. Ceramic?
I don't know off the top of my head if the sockets for the H1 lights are the same as the H4s. Something in the back of my mind tells tells me that's the case. If true, you can get ceramic H4 plugs from Daniel Stern (yes, I know...) and here at candlepower.com
Kevin
Old 12-08-2009, 05:49 PM
Why would you need ceramic plugs? I think mine are pretty standard phenolic of some sort.
Stephan Wilkinson
Old 12-08-2009, 06:09 PM
