project 911's Avatar
Throwout bearing question
Hi all,
Before I sift through all the archives (have a long drive in the morning). I just noticed what sounds like my throwout bearing growling. I can hear it clearly when the car is in neutral with the clutch out. My question is: Am I in immediate trouble, or will it just make noise?
This is a 71 T with the 911 transmission. I was under the impression that the PO had work done on the clutch not long ago.
Like I said I have drive tomorrow so I want to know if I should be worried.
Thanks for any input.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 07-29-2005, 02:21 PM
Anyone?
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 07-29-2005, 04:24 PM
It could also be your pilot bearing (roller bearing on the crankshaft-transmission input). Depending on how it fails you could loose the ability to engage/disengage the pressure plate. What will happen if the TO bearing gets bad enough it could break the clutch fork. Mine was squelling really bad for about 5000 miles before I got time to replace. It only squelled when I let out the clutch.
$.05
86 911 coupe
2001 VW TDI
Old 07-29-2005, 05:15 PM
Thanks-
I'm hoping that since I just started hearing it, that I have a little time before something bad happens. Summer is short enough without loosing drive time.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 07-29-2005, 05:24 PM
