aka 'vageen'
unclebilly's Avatar
Replacing the oil Lines
I've decided to replace the 28 year old oil lines on my car. What size wrenches do I need to unbolt them? I measured with my verniers and came up with 1 7/16" or 36mm and a 1 3/16" or 30.5mm. I have box ends in the imperial sizes but no open ends.
What size wrenches have you guys used? I don't want to mar things up with a pipe wrench but will if I can't get the wrenches I need.
Will I need any O-rings or are they flare fillings on the oil tank / thermostat/union with the oil tube going to the engine?
76 930 - featured in Sept 2013 Pano
Yoosta have: 90 C4 Targa, 87 944, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche
Old 07-06-2005, 10:24 PM
Chuck Moreland's Avatar
Get the proper size open-end wrenches. A pipe wrench will bugger it up and you may not even be able to fit it to some of the fittings.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-06-2005, 10:53 PM
randywebb's Avatar
Pelican sells the whole set - 27, 32, 36 and one other size.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-06-2005, 11:35 PM
fred cook's Avatar
Cool A wrenching pain.....
To remove the oil lines you will need (at least) the 30mm, 32mm and 36mm wrenches. If you get the Porsche specialty wrenches with the open end and a straight handle, you can add a pipe extension if necessary.
Good luck on your project!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-07-2005, 03:51 AM
Heck I'm only 5 not 66!
targa80's Avatar
If you are planning on removing the oil lines from the thermal switch and the trombone cooler line (this is if your car has them?) then be for warned that there is great potential to do damage to the threads on the lines and the thermo switch. After 20+ years of heating and cooling the connections become frozen and will require liquid wrench/heat and a lot of torque to break them free. I literally destroyed my thermal switch trying to remove the oil lines. I eventually removed the oil lines/thermal switch/trombone as one piece and then used liquid wrench/heat and wrenches with pipe extensions to break the connections.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 07-07-2005, 05:00 AM
1yearonLy's Avatar
Should the oil lines be replaced periodically or only if they appear damaged/corroded?
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-08-2005, 01:22 PM
randywebb's Avatar
only if damaged - corrosion on the outside can be cleaned off
the metal lines will last longer than you do
squeeze the rubber oil tubing every year to see if it is getting squishy
Old 07-08-2005, 03:20 PM
1yearonLy's Avatar
Originally posted by randywebb
the metal lines will last longer than you do..
I'm impressed. That explains the high replacement cost!
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-08-2005, 03:23 PM
Administrator
Jack Olsen's Avatar
The first step in replacing old (but functioning) oil lines should probably be to get pricing on the replacement pieces.
Elephant Racing makes the only lines I've seen that are an improvement on the factory design. Other common replacements like flexi line are inferior to what they're replacing, since they provide very little cooling capability -- which the factory lines do very well.
Old 07-08-2005, 04:20 PM
I used big adjustable wrenches (cheap from northern tool). It worked and cost less than buying the specialty wrenches. I'm not sure iff you can get 'em all this way. I just did the ones necessary for pulling the engine. Local Porsche mechanic told me I needed to replace the hoses cause they were leaking. I tightened them up 6 months ago and no leaks since then.
86 911 coupe
2001 VW TDI
Old 07-08-2005, 05:11 PM
aka 'vageen'
unclebilly's Avatar
I bought the wrenches taday... Not sure why I would have needed the 32mm wrench but anyway...
The line on the tank came loose easy, and the line going to the engine came loose quite easy too.
I should have read this a little more closely...
"be for warned that there is great potential to do damage to the threads on the lines and the thermo switch"
One of the threads on the thermo switch stripped. Anyone got a spare for sale?
I was planning on just having an industrial hose place replace the rubber parts of the lines - it will cost ~ $20.
Old 07-08-2005, 06:51 PM
targa80's Avatar
[QUOTE]Originally posted by unclebilly
[B]I should have read this a little more closely...
They sell a thread saver insert to fix this kind of problem.
Pat Henry
Targa80
Old 07-13-2005, 07:06 AM
aka 'vageen'
unclebilly's Avatar
Well I resolved my problem without replacing the thermostathousing.
It seems that our German engineer buddies left an extra .25" of thread on the thermostat so I ground .125" off of the length of the fitting (basically the buggered threads) and then used a 1.125" countersink bit to rechamfer the bore so the compression fitting would have somewhere to seat. It's all good now.
Old 07-18-2005, 05:34 AM
randywebb's Avatar
"Ya Hans - extra threads! Ve know ze dumbkppf Americans vill be messing mit our cars in 50 years. Zey vill appreciate our superior engineering..."
Old 07-19-2005, 10:26 AM
