Help, white smoke from dashboard???
I started my car and white smoke poured out from the top of the dash board, what is this??, a blower going out, bad wiring... Well i then turned the car off and restarted it a few days later and much to my surprise "no smoke"???, now im really baffled, please help with your advise.....Thks damian.
That was probably part of the wiring harness burning.
Disconnect the battery cables and do not put them back on until you find the problem. Check the wiring that P AG cleverly installed with NO fuses first.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
ONE MORE TIME:
Disconnect the battery cables immediately and do not put them back on until you find the problem.
thks i just did and i will look for the problem this weekend. what do you mean by P AG?
porsche automotive group, no?
my fresh air fan burned out last summer, filling the cabin with smoke. easy replacement. for a quick check of other possibly burnt wires, just pull out the tach and speedo. you can get a really good look at the wire harness inside the dash. and if you see crusty burnt insulation, trace that wire into the loom, and make sure that it did not overheat any other wires. the power going to my clock/glove box light toasted a couple of other wires, but as far as i could tell, nothing fatal came of it. i just cut back the tape wrap on a couple of sub harnesses, patched up the other melties, and taped it all back together. your results may vary.
-mik ______________________ 1978 sc coupe: i want it back |
911 user
Could it be the gas from the aircon (if fitted) escaping suddenly?
Where once the giants walked now Mickey Mouse is king. My other car is also a Porsche. |
well, maybe - but this is a known problem area
the wiring harness is spendy, maybe NLA, and a lotta lotta labor I had some idiots at a shop not bolt the battery back down after they had it out - nearly cost me mine. If you're lucky it burned itself out in time to stop current flow or is just a blower or something cheap -- but be sure.
thks if i remember correctly, it was a white smoke but i didnt have a burn smell, like a normal smell would occur when wires or plastic is bu rning thats what had me thinking....if it is the blower where is it, is it in that cube in the trunk by the gas tank??, is it made by BEHR?
hmmm. when my blower went, i definitely smelled the smoke.
