-   -   tell me about the difference between 3.0 and 3.3 turbos. (http://forums.pelicanparts.com/porsche-911-technical-forum/229968-tell-me-about-difference-between-3-0-3-3-turbos.html)
air-cool-me 07-07-2005 04:01 PM
3.0's have a shorter stroke (70.4mm)?
the use 95mm pistons with 6-5 as opposed to 7-1 comp ratio
do they have the same piston squirter's?
are the upgrade paths relatively the same?(euro exhaust,intercooler,k27)
will the extra .5 a point of CR make a bid difference in the off boost performance?
what else can you tell me about the early 3.0?
thanks
-nick
cowtown 07-07-2005 04:12 PM
3.0s have a higher-capacity fuel distributor. Same upgrade path, starting with removing thermal reactors and installing an intercooler.
air-cool-me 07-07-2005 04:34 PM
then NA's or 3.3's?
cowtown 07-07-2005 04:49 PM
3.0 930 fuel heads flow more than 3.3 930 fuel heads, from what I have read. They can be retrofit to later engines. ImagineAuto also does an upgrade to get higher flow, I believe.
air-cool-me 07-07-2005 06:21 PM
thanks!
