randywebb's Avatar
Things TO DO When Buying a 911
I thought this might make a helpful thread -- esp. after the white smoke under the dash post recently.
I'll make a bare bones start:
- change all the fluids -- engine oil, tranmission oil, and brake fluid
- unless you know for certain that the rubber brake hoses are only a few years old, replace them with factory rubber hoses when you flush the old brake fluid. Avoid the braided steel hoses unless you are a hardcore racer with a budget to match -- you'll be changing them frequently.
- go thru all the fuses and be sure they are not higher rated than they should be - rotate/twist each one and check for corrosion
- add a fuse to ensure that all wires under the dash are fused
- add relays for the headlights - the Sucro kit is fine and he is very helpful if you have problems.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-07-2005, 09:57 PM
bigchillcar's Avatar
fuel filter..i still hear horror stories of people going yearrrrs without changing them..and why not the air filter as well. check condition/proper tension of fan belt. i'd also open up all the headlights and taillights and look for corrosion/replace bulbs at all 4 corners. drive piss out of car..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 07-07-2005, 11:46 PM
Sonic dB's Avatar
Dont forget the coolant flush and check the RMS if buying any Porsche built after 1998.
Old 07-08-2005, 12:25 AM
kqw kqw is offline
Wash and wax the car. This will tell you the condition of the paint and reveal the nicks and dings.
Begin your journal/records of what was done maintenance wise.
Lubricate all linkages, check all hoses and their connections.
Learn how the drive a 911. If it's your 1st P-Car, it'll take you about a year to really know the car and how it handles in different situations.
Get a radar detector.
Donate to the local PD's charities. This may assist you in not having to donate to the local coffers.
In winter, run the A/C at least once a month.
Establish a "secret" stash of cash if you can. This for the little upgrades and such that you don't want to explain to the significant other.
If you don't already have them, get extra keys made.
Mark your spot in the garage and it's parameters.
Alarm the car.
Check your tools and add to them as necessary.
The Fox
Carrera
Old 07-08-2005, 03:41 AM
Doug&Julie's Avatar
Originally posted by kqw
Mark your spot in the garage...
My car does that all on it's own!
Take lots of photos to document your car at the time of purchase and as you make "modifications". Digital cameras are wonderful.
Keep electronic files along with your "paper" files as records. IF you ever sell the car, we're in a digital age and being able to e-mail records/photos is a major help. If you don't sell, they're still nice to have as records or to see "how far you've come".
Buy "fix-it" style books to help you learn the car, even if you're never going to touch the car yourself. Knowledge is power.
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 07-08-2005, 05:05 AM
All good points, also need to check tires and mainly the wheels; looking for cracks and dints damage.
Old 07-08-2005, 07:11 AM
open a home equity line of credit.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 07-08-2005, 07:27 AM
Banned but not out, yet..
RSBob's Avatar
Inspect fuel lines thoroughly. If old, or in doubt, replace immediately.
And following on what Ken says, better take out a second home equity line of credit or marry a Hilton. On second thought.... go with the credit.
Old 07-08-2005, 08:16 AM
RETIRED
Joe Bob's Avatar
Buy gold chain.....ooops, wrong board.....
2012 ML350 3.0 Turbo Diesel
Old 07-08-2005, 08:55 AM
Send a message via AIM to ajackson
don't open a home equity line of credit!
Alan Jackson
77 911S 3.2
Old 07-08-2005, 09:13 AM
Registered abUser
TerryH's Avatar
Yeah, just re-fi and pull out all the equity. Then hold weekly garage sales to supplement your future P-parts habit. Then get your wife that second job.
'81 911SC Coupe SOLD
Old 07-08-2005, 09:21 AM
check the shift coupler bushings
lube and preload front wheel bearings
86 911 coupe
2001 VW TDI
Old 07-08-2005, 09:41 AM
Johnathan's Avatar
Having recently bought my first 911 this is a great thread that all new owners should see.
1983 911SC Platinum Coupe
2007 Ford F150
Old 07-08-2005, 10:42 AM
pa911's Avatar
Don't keep track of how much you spend on it.
Old 07-08-2005, 11:03 AM
burn or throw away all receipts from day one..
ryan
Old 07-08-2005, 11:04 AM
Rodney Nelson's Avatar
1. Check Battery Boxes for corrosion. Clean up and add a Battery Pad underneath the battery.
2. Change the wipers
3. Inspect Headlight and Fog Light Lenses, may need to repalce. Check to make sure all Bulbs are working as well.
4. Change Oil
5. Change Air Filter, or upgrade
6. Change Tranny Fluid
7. Inspect Tires, look for dry rot uneven wear
8. Inspect Brakes, pads, rotors etc..
9. Change Fuel Filter
10. Lubricate all linkages
11. Adjust Clutch if necessary
12. Align and balance tires if pull or shake is noted while driving
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 07-08-2005, 11:19 AM
Formerly bb80sc
Vipergrün's Avatar
Setup a delivery location other than your home for those many boxes from UPS
Buy your wife flowers often. Makes it easier for her to say "yes"
Drive the car and rev it high, no garage queens.
Offer to share the Porsche experience with the neighbor kids, take them for a ride.
Get to know your car and be careful when driving. It's fairly easy to swap ends.
Take your car to the track at least once and get instruction from a good 911 driver. These cars are amazing, even in their stock form.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 07-08-2005, 11:53 AM
