-   -   Lugging an engine with a tiptronic? (http://forums.pelicanparts.com/porsche-911-technical-forum/230050-lugging-engine-tiptronic.html)
superfans 07-08-2005 01:30 AM
Can one cause an engine to lug with a tiptronic (e.g. cruising at a low rpm with a high gear)?
svandamme 07-08-2005 02:16 AM
doubt it, cars with tiptronic allready have more grunt in the low rpm anyway , it's not as critical as would be with an early S engine.
ok , in manual mode , you could probably get low rpm in high gear
and i doubt there's a point in doing so , but really lugging the engine , you'de have to be really low in RPM
all depends on your engine really, at what point does it begin to produce torque?
superfans 07-08-2005 02:21 AM
The reason I ask is because sometimes when one cruising at overdrive and wish to accelerate quickly, the transmission may not shift down a gear immediately and the car may try to accelerate at 4th or 5th gear slowly. If this happens, then should we manually shift down a gear before pushing for acceleration.
svandamme 07-08-2005 02:27 AM
downshifting is fun... go for it
superfans 07-08-2005 02:33 AM
So I guess we just can't rely on the computer to downshift for us, isn't it? and the solution would be to downshift ourselves in order to boost the rpm higher.
svandamme 07-08-2005 02:43 AM
if the 'puter thinks it can make it , it won't downshift
but that just means the 'puter is a boring fart , who cares more about fuel economy, not that he can't be relied on.
Deschodt 07-08-2005 11:39 AM
I was wondering the same on my Wife's CVT Audi A4... Not so much lugging but the tranny will shift to 7th gear any chance it gets (well, 7th is a relative term on a CVT tranny but that's what it says), which does not sound like a great way to "break-in" a new motor !
I've made a point of driving it harder and in sports mode to make up for that...
Lugging per se is impossible on a tip, I'd say.. Lugging is when you press the gas pedal hard at low RPM in a too high a gear. A tip will downshift in that situation. Dirving at low rpm in high gear and accelerating slowly is not lugging !
superfans 07-09-2005 02:01 AM
My experience is that the computer will shift down one gear or two for you 90% of the time when you step on the gas. However, it seems that there is still 10% of the time where the gear will, for example, stay with 4th when you press the gas and the car accelerates slowly because of the low rpm. Will this be similar to a lugging situation?
Todd Simpson 07-09-2005 08:58 AM
If the RPM is below 2000 and your foot is floored, then yes, you could be lugging.
It is doubtful though, the "manual" automatics I've driven will all downshift in that situation.
Just check the tach.
