Send a message via Yahoo to drophit
Any suggestions
I am baffled, yes big time. Need a guru of transplants to help.
I have a 75 911s with an 87 Carrera motor.
Problem:
My oil level gauge pins to the top when ever i either:
A. Have the headlights on.
B. With the key OFF, use the right curb lights/right turn signal
I know it is a ground but hwere would you think it to be? Or, is it a bad gauge
Z
Z
Old 07-08-2005, 01:00 AM
pa911's Avatar
sounds like your right tail light wire is crossed with tank oil level sender.
Old 07-08-2005, 02:05 AM
IROC's Avatar
One thing that needs to be done when you install a 3.2 into your car is to move the location of the 14-pin connector in the engine compartment. The cable that feeds the rear tail lights, backup lights, etc, is an integral part of the cable that contains the 14-pin connector, so this portion of the cable (going to the rear lights) needs to be cut and spliced. I would suspect that you've got a problem in this area. Might be a good place to start looking.
Good luck,
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 07-08-2005, 04:30 AM
Hum ok will look into the tank level wire and the tail light.
Coudl you elaborate on this 14-pin connector, as i am new to the porsche, is there a posting somewhere to see how to do this?
Z
Old 07-08-2005, 11:59 AM
IROC's Avatar
The 14 pin connector provides the connection between the engine and the car and carries things like wiring to oil temp and pressure sending unit signals, starter wire, etc. It is located on the driver's side of the engine compartment, near the rear of the car. Can't miss it.
Anyway, like I mentioned, the wiring harness that contains this 14 pin connector also contains the wiring that continues on back to the left tail lights, etc.
Maybe a place to start looking...
Mike
Mike
1976 Euro 911
Old 07-08-2005, 12:04 PM
IROC's Avatar
OK, I just re-read this and you're talking oil *level*...sorry about that. I was thinking oil *pressure* for some reason.
My bad.
Mike
1976 Euro 911
Old 07-08-2005, 12:05 PM
Work in Progress
Rich76_911s's Avatar
Here is a web site that shows where pins need to be moved in the 14 pin connector. I don't know if that helps but figured it might. Good luck.
Rich
http://www.pelicanparts.com/MotorCity/marcesq1/
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 07-08-2005, 12:18 PM
Thx great resource!
Z
Old 07-08-2005, 12:59 PM
