OK, it finally happened. The rubber boot which interfaces the Air Flow Meter to the Throttle Body finally gave way after 2 years and tore. I suspect because of the high boost pressures I run (1.25bar)
![]() As the pic below shows, it tore right at the junction where the T-Bolt clamp fastens the boot to the throttle body. Is this a common area where these tear? If so, is there a way to actually strengthen this area? I'm thinking of perhaps lining the inside of a new boot with extra tough, cloth lined tape. Would that work? Any ideas/suggestions?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Looks like I'm going to have to do this mod and go to a Nitrile connector which'll handle the sort of boost levels I'm running
When I did my EFI conversion, I eliminated that rubber ell and used an Alu. ell instead. I heard the rubber ones failed with boost.
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Merv, I had my AFM machined for the pipe, and a barb lip cut in it for the boot for $95.00 USD... worth it I think.
Todd @ protomotive said that you could run the stock boot, but "there is a single place they all eventually blow out". I guess that's where it is
David Avery 05 Lotus Elise (sold) | 08 BMW 135i visit FocusedE, my e-business company | visit Spyderclub |
Hmm..I'm not a fan of having AMM on the pressure side unless it's hot-wire AMM secured with heavy-duty ruber hoses.
Thank you for your time, |
![]() BTW, what size should the barb fitting be for the Idle Speed Actuator valve hose? Is it 5/8" ID? Can someone confirm please?
Hi Merv
Todd had me drill a .625 " hole and tap with a 3/8" pipe tap... hope that helps.
Thanks mate!
![]() Just a tip for anyone else considering such a mod and wants to save some cash
Wydryd, what did you end up doing. i am having the same Problem
Williamknightperformance.com Perfectpower.com |
YermanCars, I did exactly the same mod as shown above, using a 90 degree Nitrile connector and a brass 5/8" NPT fitting tapped onto the AFM. Works great! I can't believe how much HP I was losing with that turn boot
![]() Oh, make sure you block off the metal vacuum pipe that use to go into the OEM rubber boot. It's not needed once you go to the Nitrile connector.
Somewhere in the Midwest
The intake is being modified to draw low pressure air through it, upstream of the turbo. The AFM blew up last night when someone was being a bit heavy footed (Just kidding T)Actually, from what was described to me the AFM may have been a rebuilt unit.... |
Here's a pic of the mod I performed.
![]() ![]() I'm not overly wrapped with the kink in the Nitrile connector's bend radius. May have to remove it again and trim it up so it forms a nice consistent bend radius from AFM to Throttle Body. For now, it works fine though and I've only tested it up to 1.1bar and am quite surprised at how much HP I was losing with that torn unit
Original Owner
Looks like a short radius elbow or Cobra head needed.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
There is a short radius 90 degree rubber (or silicone) elbow available. It's 0.25-0.375 inch wall thickness, and it fits perfectly between the AFM and the TB.
Friend of Warren
Any chance of finding some PVC pipe that would fit? Could always paint it some color other than white.
Kurt V No more Porsches, but a revolving number of motorcycles. |
