jpahemi's Avatar
Rear PORSCHE reflective panel. Removal.
Does anyone know how to remove the rear PORSCHE reflective panel? My car is an '84 and I've heard it's held on by clips; can't seem to find these clips.
TIA.
J.P.
Old 07-08-2005, 11:35 PM
bigchillcar's Avatar
many are held on by sticky double-sided tape..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 07-08-2005, 11:53 PM
Up above the muffler is a long sheetmetal cover held on by screws. Remove it and you can get at the clips. You will need to spread the spring clip teeth away from the plastic studs they are on and the reflector will come off. I used a pair of needlenose pliers and a small screwdriver.(Car was an SC)
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 07-09-2005, 05:26 AM
jpahemi's Avatar
john:
Have you removed the reflector? I checked the area you described and found exactly the panel that needs to be removed for access. I'm looking to polish the surface and wonder if it's worth removing for this. If there's a chance of breaking the plastic studs, then it may be better to polish on the car. Your thoughts??
Regards,
j.p.
Old 07-09-2005, 08:29 PM
The plastic studs are about 1/2" dia. . They are fairly strong. I had a reflecter that was damaged by paint remover when stripping the body prior to a repaint. I replaced it with a good one I bought on Ebay. I would try to polish on the car because of the nuisance getting it off and on more than the chance of damaging it.
1995 993 coupe
2012 Boss 302
Old 07-09-2005, 08:34 PM
jpahemi's Avatar
Thanks John. 'Don't want be a victim of Murphy's Law.
j.p.
Old 07-09-2005, 09:38 PM
