-   -   AR Concepts 911R tail light question ? (http://forums.pelicanparts.com/porsche-911-technical-forum/230336-ar-concepts-911r-tail-light-question.html)
rdane 07-09-2005 08:49 PM
More than one of us using them. Would other's mind posting their car's? Also what did you use for a seal between the bumper and the car's body? I am looking for a single piece of trim to seal up the rear impact bumper..
Thanks!
These are just the ones I could fine.
http://forums.pelicanparts.com/uploa...1106517107.jpg
http://rennlight.com/howto/911r/5000014h.JPG
http://forums.pelicanparts.com/uploa...1102342475.jpg
http://forums.pelicanparts.com/uploa...1099486850.jpg
http://forums.pelicanparts.com/uploa...1117640430.jpg
I have a gap here I want to get rid of. Do I need to add to the bumper?
http://forums.pelicanparts.com/uploa...1115950437.jpg
mjshira 07-09-2005 09:29 PM
http://forums.pelicanparts.com/uploa...1120969756.jpg
mjshira 07-09-2005 09:31 PM
http://forums.pelicanparts.com/uploa...1120969877.jpg
Jack Olsen 07-10-2005 01:06 AM
The first car pictured (mine) doesn't have the AR Concepts pieces. Mine are one-off's from before AR Concepts was making them.
AR Concepts' pieces have much better fit and finish than mine, but faithful reproductions of the 911 rear bumper still leave a gap below the light assembly. Maybe AR Concepts (or someone) should make a bumper with tighter tolerances than the factory specified?
widebody911 07-10-2005 01:29 AM
I don't have seals on mine, and mine has a funky 'ledge' to the left of the leading edge of the light due to excessive bondo in the quarter panel.
randywebb 07-10-2005 10:44 AM
Has anyone ever used body putty to fill in the cracks/lines where the part fits into the body?
I'd like to see what that looks like...
mjshira 07-10-2005 11:07 AM
no, you don't need a gasket. At least I have not and I have driven mine in rain many times. I am actually replacing a bulb at the moment. Important is to use some silicone to seal things up to keep the water out.
rdane 07-10-2005 04:34 PM
Thanks Jack. I had wondered if it was just mine. I'll give Dave at TRE a call on Monday and see if they have found an answer for the trim seal.
