Grand Am/IMSA Data Guy
Porsche84's Avatar
Rear wheel bearing source needed
Hi Gang
I have been reading some prior threads on wheel bearing failures and sources for different bearings. I have been chasing a problem on my car for a couple of years. I have replaced banana arms, machined them to bring the bore back into spec, added large metal rings (in place of e-brake set-up) to add strength etc. My car is an 84 and only used for track (DE and a little vintage). My parts sources (Westex and SSF) both send the same bearing SKF 305988D. Last summer I bought a pair though the Porsche dealer, they were exactly the same numbers, different box and 2x price, as my suppliers. I noticed on a prior thread that someone used a p/n SKF 309609ad, and someone included a photo of a bearing made in Italy. I need to find better quality/durability bearings. Any help finding a source would be greatly appreciated.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 07-22-2005, 09:40 AM
DW SD's Avatar
UMMMM, Pelican sells virtually ALL Porsche parts? Why don't you call them???
1971 RSR - interpretation
Old 07-22-2005, 10:15 AM
BOUGHT MINE FROM PELICAN PARTS.
Old 07-22-2005, 10:17 AM
Wavey's Avatar
I've got a pair of rear wheel bearings sitting here, recently purchased from our host. SKF, # 305988D, made in Spain. Unless this bearing also fits something else, I doubt if you're going to find anything better. Any chance you're damaging them when installing?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 07-22-2005, 12:44 PM
Bird. It's the word...
Fishcop's Avatar
I think Jerry was asking for help in relation to brands and opinions... I suspect he knows where to buy them
The originals in my car were FAG, and I had a choice of Timmken (sp) or SKF to replace them. I went with the SKF and no problems so far. The threads I read flagged a possible issue with outer diameters of the various brands (we're talking fractions). I also used a bearing retainer compound to be sure.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 07-22-2005, 06:29 PM
Porsche84's Avatar
Wavey
I have been replacing these wheel bearings for a number of years, on many different 911's. I have all of the correct tools. I am confident I am doing them correctly. That said, the units from SKF (305998D) just do not hold up to the strain on the track using Michelin Sport Cups, or Hoosier racing slicks. I am looking for a bearing that has proven to hold up better than the "Spain" version. I am very leary of just ordering replacement because 3 different sources have sent me the 305998D, and now you say PP sells the same. Hoping that someone has a source.
Thanks and keep the info coming
Jerry Austin
Old 07-22-2005, 06:32 PM
I have no hard experience on this so
afaik, based on a BusinessWeek article, the Timkin Brg mfg spends the most on R&D, has the most expensive facilities, etc, and produces the finest bearing in the world.
I also got a heads up from a bearing pro, that was visiting this site, when I asked him about my info. He said that on your street car SKF is good enough.
I may be able to search his name if you need it later and get his view on a track car ?
also fwiw, is this issue due to grease failure ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-22-2005, 07:54 PM
randywebb's Avatar
I went to college (Crass Western Perverse Univ. -- aka "Case") with a Timkin offspring and ... they are very proud of their bearings.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-22-2005, 09:20 PM
