I was reading the Sep. issue of Excellence I just received and came across Jim Pasha's article in the Tech. Forum (p.172.). It seems that some of the wires for the glove box lamp are too close to the bulb. One owner had the insulation melt causing a short, melting his wiring harness. I checked my own cars- the SC was OK, but sure enough, the Carrera had a loop of wire touching the glove box bulb (which gets very hot, BTW). I simply moved it out of the way and reinstalled.
Ray '88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia |
Unregistered
LOL, not a problem is your glove box bulb doesn't work
True enough Sammy. This might be the reason.
that same harness fries when the disconnected trunk light wire touches ground below the right hinge. not many people tape the end, and leave it hanging.
i just removed all that for the longhood and duck i put on my car. I don,t remember taping the wires so i will check them first.Cheers,
87 Carrera Backdate |
Don't forget the famous front condenser motor harness that melts and short if the condenser motor is frozen.
yeh - I saw that - it makes you want to throttle the moron who designed the elec. system for our cars.
Now - does this only affect teh 3 & 3.2L cars? Or does it affect any others? This is a good thread to compile all the previous very important elec. fixes for our cars.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
On a great circle route
Russ |
It might seem like a funny question, Russ, but Halon won't help much with an electrical fire due when a short circuit is present in an unfused power lead! Ever hear of the Brown's Ferry nuclear power plant fire in the control circuits???
http://www.ccnr.org/browns_ferry.html
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Warren Hall Student
Interesting report Warren. A little scary though.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
This article struck home with me after having already replaced one wiring harness. Huge PITA and very $$$. Warren is again correct- by the time you smell it, you're fried.
It's pretty scary. Back about 15 years ago I had spent 10k on a complete strip/paint and 3.0 conversion on my 75 S.
That same harness shorted out on the ash tray or radio light. I can see the wire starting to glow red and the smoke started to pour out. I was lucky I was on a 2 lane road with no traffic. So I could shut the car off. Man do you feel helpless.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
I put a 7.5 amp fuse on my front condenser blower just in case it tries to melt down. Got the tip on this board.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
anyone know where the front air box motor is tied in at the front elec panel ?
I don't use it and would like a disconnect. thx
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
