Unknown device near CD unit!?
Hi there:
had planned to install an ignitor unit this past weekend and explored how to hook it up. I noticed a unit installed on the left side forward from the CD unit and I couldn't tell what function it might have. Has anyone see anything like this before? http://forums.pelicanparts.com/uploa...1121056423.jpg In this picture below I assume the Motorola device is an external regulator and was installed in replacement of a stock unit!? Is this perhaps the reason that the condenser on the outside of the Bosch distributor is not connected? http://forums.pelicanparts.com/uploa...1121056451.jpg Thanks & cheerio, Harry. |
That looks like a starter solenoid for Ford.
the dingus in the top pic is an obvious PO add on - look at the crimps on the Fastons...
your 2nd post makes sense to me... what year car are we talking about? |
Hi, this is a 1971 911T.
Cheerio, Harry. |
Harry, looks like PO added that Ford-style starter solenoid(there used on lots of domestic vehicles) either because the stock one died or to combat a "hot-start" problem.
The distributor condensor(attached to the points) prevents sparks from potentially jumping(arcing) across the points as contact is broken. (which in turn would lead to pitting and a dramatic reduction in points life). E.g. it 'absorbs' the volts that might otherwise 'jump' across the opening points. If your distributor has been converted to an electronic Pertronix/hall effect system type system then no condensor would be needed. |
The PO must have been an electrician by the looks of the stake on terminals on the stranded #12 THHN wire.
Joe |
I guess now you can say you have a "hybrid" vehicle.:-) |
Cheerio, Harry. |
I don't know, but that small cylindrical thing to the upper left sure looks like a condenser.
I think that condensor near the regulator maybe to control RF interference/ noise suppression.
Should a 71T have a dist. condenser? My 77S doesn't.
Harry,
Your '71 911T came with OEM Bosch CDI ... which doesn't use a condenser across the points, since only around 420 mA are being switched through a 33 Ohm pullup resistor inside the CDI unit as a trigger signal ... that condenser hanging off the distributor must have been added by someone unfamiliar with CD ignition! The Ford solenoid is being used as a 'booster relay' to give a hotter, healthy signal to the starter solenoid ... possible issues with the ignition switch may exist, 14-pin connectors at the relay/regulator/fuse panel, or corrosion inside the starter and solenoid. |
Hi Warren,
I am beginning to think that the car may have been equipped with a Marelli distributor and retrofitted with a Bosch distributor used in a different vehicle wo/ CDI system... Thanks Warren and everyone else! Cheerio, Harry. |
| All times are GMT -8. The time now is 07:09 AM. |
