Please make my car shut off
It must be something simple right. 930 won't stop running. I know it must want me to drive it as much as I can but come on!
It has a new ignition/fuel cutoff relay. John Walker, are you out there, and did you get the gift I sent for fixing my last problem. I sent it last week. bw |
??!! If it won't stop, we can all take turns driving it, bring it over.....I'll go first
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Still Doin Time
Possibly the electrical portion of the ignition switch bad OR the mechanical part of the switch is not returning to the 'off' position even though it may feel like it.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Ed, you can drive. Nice little run on Josey Lane from 544 north to 121. Try it at full speed some time.
Ign. switch is fairly new. |
That is a fun little area. I've got some neat country roads (Argyle area) near my house that are fun too. Hope you get it solved, but if not.....
Seriously though if you were need to shut it off have you tried to stall it out?
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Well, I'm not exactly drinking a beer, typing on my PC while it purrs in the drive. I dumped the clutch. Do you think I can explain that move to the Valet?
930s have a built in run-on circuit that keeps fuel pumping for a few seconds after you shut off the ignition. I am not entirely sure why Porsche did this, but perhaps it was to act as a turbo timer to help cool the turbo a bit and prevent oil coking after a hard run. In any case, a bad run-on switch could cause it to continue to run after the ignition is off. In the meantime, you could just pull the fuel pump relays to get it to shut off.
Bill |
Bill, I changed the relay you speak of a few weeks ago. It is to run the eng for a few seconds to burn fuel in the intake after shut off. I think the true name is ignition cut off relay.
I wonder if there is something wrong with the new relay?? Why did you have to replace it? I know in our 930 the engine would run on for what seemed like a little too long - maybe 10 -15 seconds - until we replaced the WUR.
Bill |
I replaced the relay because I was having trouble that proved to be my rebuilt cd box. I wanted to make sure it wasn't keeping my car from starting. I have the old one, I will swap.
Switched out for the old relay. Still won't quit.
One of the diodes in the alternator may have gone bad and is letting current pass through the electrical system. Gave me fits until I R&R'd the alternator in my '73.
Jim |
Alt was replaced with new unit from Porsche about 2 1/2 years ago. How do I test in the car? Out of the car?
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
I am using a replacement box. I put it in on Friday, drove all day, all was ok. Sat couldnt get it to shut off. So, it might be the box not the car or some other item?
I have been chasing this as well. I haven't gone through all of the steps that you have. I just stall mine out which probably isn't great but I only run the engine 10-15 times a month.
The weird thing with mine is I get four separate conditions 1.) Turn the key off and nothing happens but tach starts to cycle high to low. Then I stall it. 2.) Turn the key off and the engine revs up and down for a couple of seconds and shuts off. 3.) Turn the key and engine revs up and down for an endless period until I stall it. 4.) Turn the key and it shuts right down as normal. For me #1 is the most frequent and #4 is probably one in twenty.
'83 SC |
My car shut off today. Only change was a blown fuse to the blinkers. Does this make any sense?
I'll double check all of my fuses. I think I've done that already (been chasing this since last year) but can't recall.
'83 SC |
see if there is a single filament bulb in a double filament socket, left rear.
