kqw kqw is offline
Oil pressure increased
When I replaced the left cam oil line and the little line that feeds the chain tensioner, my oil pressure has increased by a full bar. I.e., at 3K rpm, the pressure is at 4 bars. At 2K rpm, the pressure is at 3 bars.
I know this is a good thing, but wonder if those lines over time, oil flow diminishes because of oil varnish etc.
The Fox
Carrera
Old 07-11-2005, 09:03 PM
ianc's Avatar
Less restriction = less oil pressure... I would almost wonder if you don't have a blockage in your new lines.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 07-11-2005, 09:05 PM
kqw kqw is offline
I'll pull it again tomorrow and check. If those lines were restricted, I would certaintly know/hear it in a very short period of time if that chain tensioner was not being fed oil.
The Fox
Carrera
Old 07-11-2005, 09:23 PM
Early_S_Man's Avatar
Porsche Crest
That tiny line to the tensioner couldn't possibly raise oil pressure that much if plugged! It is the line to the cam spray bar that you should be worried about ... and you wouldn't hear anything until the cam had been ground flat!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-12-2005, 04:37 AM
greglepore's Avatar
What Warren said, and why I'm skeptical about the "restrictors"-while increased pressure may be a good thing elsewhere in the motor, the part getting less oil volume may not be happy.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 07-12-2005, 08:10 AM
kqw kqw is offline
Checked again,
The Cam oil lines are getting hot and once the car got to operating temps;
Idle pressure is at .5 bars and
3K rpm is at about 3.2 bars.
Recently went from the 10-30 to the 20-50....duh....
The Fox
Carrera
Old 07-12-2005, 05:37 PM
