-   -   Splitter material? (http://forums.pelicanparts.com/porsche-911-technical-forum/230814-splitter-material.html)
project 911 07-12-2005 05:09 PM
Splitter material?
Hi all-
I'm thinking of adding a splitter to the bottom of an RS front spoiler. I see lots of people seem to have them. Does anyone know what material would be good to make one out of? Something along the lines of inexpensive DIY stuff would be nice.
Any advice would be appreciated.
Chuck Moreland 07-12-2005 08:20 PM
I've used aluminum sheet with good results. Get .060 thick.
Jerome Ryals 07-13-2005 04:59 AM
I've use 3/16" polycarbonate and 1/4" plexiglass with good results but the aluminum Chuck mentioned would probably be easier to work with though.
emcon5 07-13-2005 07:05 AM
Plywood.
Tom
chrisp 07-13-2005 07:31 AM
I've seen plywood splitters all the way up to the ranks of the Speedvision cars. It's not an approved material for most PCA members but it works just fine. Keep in mind the weight though. If you have a glass bumper and the mounting can't handle another 3-4 lbs you may need to either use aluminum or reinforce the mounting.
911teo 07-13-2005 07:37 AM
How about rubber?
http://www.rubbercal.com/Skirtboard.html
widebody911 07-13-2005 08:03 AM
ABS plastic, carbon fiber and fiberglass also work
widebody911 07-13-2005 08:11 AM
Originally posted by 911teo
How about rubber?
Gotta love a site with animated icons like this
http://www.rubbercal.com/files/bean_...ock_md_clr.gif
project 911 07-13-2005 05:17 PM
Hmmm... Several good ideas here. Looks like I need to make a trip to Home Depot.
techweenie 07-13-2005 05:33 PM
I too have used 1/4" polycarbonate. You want the splitter to 'self-sacrifice' before taking the bumper apart, IMHO.
http://forums.pelicanparts.com/uploa...1121301212.jpg
project 911 07-14-2005 05:26 AM
I guess I'm not sure what polycarbonate is. I agree that it should be something that can break off before taking the whole spoiler if possible. I'm repairing an RS bumper that was broken in two, and wouldn't want to do it again.
Wavey 07-14-2005 05:36 AM
There's a material used in the graphics business called Sintra (also the same thing by another company called Komacell). It's an expanded PVC (same thing that plastic plumbing pipe is made from, just "foamed" a little bit). Comes in several thicknesses from 2mm (5/64") to 13mm (1/2")in black, white and several colors. Very easy to fabricate, relatively durable, relatively lightweight, and inexpensive. Any local sign shop should have some around - bet they'd even have some scrap in the sizes you need.
rsrfan 07-14-2005 09:12 AM
I bought a 4 x 8 sheet of 3/16 inch abs plastic from Professional Plastics, Inc off the web. After cutting out the splitter, I have enough material for at least one more and plenty for those small projects. I think the total cost with shipping was about $70.00. It looks great and appears very durable. JP
911pcars 07-14-2005 12:14 PM
"I guess I'm not sure what polycarbonate is."
Pretty common stuff. Used for windows of race cars. Should be available at your local home building store. Some trade names are Lexan, Tuffak, Makrolon, and Hyzod.
Here's one source: http://freckleface.com/shopsite_sc/store/html/
Hope this helps,
Sherwood
PhatRedHead 07-14-2005 12:18 PM
Originally posted by emcon5
Plywood.
Tom
"natural composites" :) the only way to go.
randywebb 07-14-2005 07:00 PM
hemp
if "natural composites" the only way to go.
JasonAndreas 07-14-2005 09:34 PM
Baytec P, it's the plastic used on the bottom of snowplow blades... :)
mmastro 07-14-2005 09:53 PM
I used 1/8" aluminum plate
http://forums.pelicanparts.com/uploa...1121403180.jpg
http://forums.pelicanparts.com/uploa...1121403195.jpg
Jack Olsen 07-15-2005 11:13 AM
I went through a 'slightly crazy' phase with several different thicknesses of aluminum.
http://forums.pelicanparts.com/uploa...1111613203.jpg
911pcars 07-15-2005 01:23 PM
Anyone familiar with the material they use as min. height/rubbing strips on current F1 cars?
Sherwood
