lateral movement?
I am rebuilding my brake calipers, and while I'm here I noticed a bit to much lateral movement of one of my rear hubs. Whats involved in resetting the bearing play?
Thanks, Paul |
Anyone; please?
Somehow, I think there's a "I don't want to go first" problem here. Many times I will post on a thread that has gone unanswered and all of a sudden the flood gates open.
The thing is here, I don't know all that much about the Carrera years. There are some subtle and not so subtle differences between those years and what I work on. Anyway, for what it's worth, I don't think there should be any lateral movement on the hub. So, sit tight and wait for John Walker or any of the many who know exactly what is going on. I seem to remember this happening to someone else and there is a fix. |
Thanks Zeke...Looks like nobody else has piped up.
Okay, I'll have a go...
I recently changed the bearings on my earlier car. I know there are some subtle differences. I had the same symptoms as you describe and it turned out that the bearings were beyond loose - they were completely shagged and failing fast. For mine I had to get a 30mm socket and a bigass breaker bar... then I added another 2' of gal pipe for leverage! These are cranked on seriously tight! To loosen I used some penetrating oil and had to stand on the end of the bar... and jump! Tightening was the reverse, although I didn't "jump" to tighten. It might pay to get to some advice on the state of your bearings. |
There shouldn't be any slop. If you torque the nut to spec and there's still slop, replace the bearing.
| All times are GMT -8. The time now is 04:02 PM. |
