How to hook up 964/993 Tach on 3.6 motor swap?
I just bought a factory 964 tach to replace my autometer one, but I'm not quite sure how to get it wired up. The 964 tach seems to have a little clip in the rear which accepts a wiring harness to hook up with all the pins. I read this thread, but there isn't much wiring detail:
Gauge update to 993/964 done (pictures)
Does anyone know where I can buy a wiring harness clip with a few inches of wire hanging out the back to solder? I would prefer this method over directly soldering wires to each pin of the tach.
- James
1975 3.6 RS
2015 F10 535i
2011 911 C2
Old 07-13-2005, 02:09 PM
Anyone?
- James
1975 3.6 RS
2015 F10 535i
2011 911 C2
Old 07-14-2005, 06:12 AM
Send a message via AIM to hahnmgh63
964/993 Tach
I ended up soldering wires on the end of the pins as like you, nobody came forward with a harness/plug. Someone said you could find wire splices or something like that which would fit over the individual pins but I couldn't find them. After I soldered on short pieces of wire I slipped over some shrink wrap around the soldered joint/pins to insulate them. MGH
Old 07-14-2005, 07:12 AM
BigKenSteele's Avatar
Try these guys:
http://www.germanautodismantlers.com/home.asp
I am sure they would be able to cut off what you need.
BKS
Cars
-n-
Stuff
Old 07-14-2005, 09:33 AM
