-   -   Another CC Servo ? (http://forums.pelicanparts.com/porsche-911-technical-forum/231000-another-cc-servo.html)
Porsche80 07-13-2005 05:54 PM
Another CC Servo ?
I need someone to confirm 2 things
1. If you disconnect the CC electrical connector on the servo and then in turn with an ohm meter, ohm out each of the 2 pins on the servo with one of the probes attached to ground. Does the meter show a short?
2. If you move the throttle (at engine) does the cc cable easily move in/out of the servo?
C
