-   -   Replace voltage regulator on 72T (http://forums.pelicanparts.com/porsche-911-technical-forum/231006-replace-voltage-regulator-72t.html)
wahoofan 07-13-2005 05:24 PM
I think I need a new voltage regulator on my 72T. Lots of the classic symptoms I've seen mentioned on this board.
Can I replace the VR itself, or will I need to replace the alternator as well?
techweenie 07-13-2005 05:29 PM
It's a pretty easy replacement. I believe there are two types of VR/alternator used on the '72, so you need to be sure you get the right one. I think it's a screw or two and the actual connections.
There is also an alternator with an integrated VR, so if you could shoot a picture of the electrical panel (driver's side of engine compartment) and post it, we could probably give you some help right here.
pwd72s 07-13-2005 06:39 PM
Assuming all is stock...a big assumption these days, either a SEV Motorola or a SEV Marchal works...only the cover is different. Stock '72 alternators used the external V regulator...
wahoofan 07-24-2005 06:27 PM
Thanks for all the info! Does this picture help at all?http://forums.pelicanparts.com/uploa...1122258400.jpg
Early_S_Man 07-24-2005 07:00 PM
The regulator is mounted on the fuse/relay/CDI/electrical panel on the left side of the engine compartment [bolted to inner fender panel] ... under the black plastic cover secured by an M6 plastic wing bolt ... located aft of the CDI unit [with Yellow <b>'Vorsicht!'</b> warning label with Red Lightning Bolts on it] ...
The alternator and regulator could be Bosch or SEV Marchal/Motorola ... but the regulators are each a distinctive shape, easily recognized in even a fuzzy pic! All '64 thru '73 regulators use screw terminals and lugs on the individual wires ... not the 3-pin plug used on 1974 & later cars!
RoninLB 07-24-2005 07:15 PM
SEV Marchal regulator from my stock '77
http://forums.pelicanparts.com/uploa...1122261336.jpg
pa911 07-24-2005 08:04 PM
I'm no expert, but it seems I read on here somewhere that it didnt matter what VR you use even one from the local auto parts store would work. is this correct?
Zeke 07-24-2005 08:09 PM
Even if you got it to work (which it might), that is not correct. Buy the specified part. Electrical systems are a balance of amperage and voltage. A wrong battery can make a difference on some cars like British cars that have Lucas electrics. Get the right part.
Early_S_Man 07-24-2005 09:20 PM
Here is what all '69 thru '73 Marchal/Motorola regulators look like:
http://forums.pelicanparts.com/uploa...1122268781.jpg
bigchillcar 07-24-2005 11:05 PM
The regulator is mounted on the fuse/relay/CDI/electrical panel on the left side of the engine compartment [bolted to inner fender panel] ... under the black plastic cover secured by an M6 plastic wing bolt ... located aft of the CDI unit [with Yellow 'Vorsicht!' warning label with Red Lightning Bolts on it] ...
warrenspeak translated: 'no..aim your camera more to the left..'
:D
ryan
wahoofan 07-25-2005 07:34 AM
Thanks guys - Warren's pic looks exactly like what I just found when I opened the cover. So I just disconnect that thing and take it to the import parts place (owned by a guy with a 75 911s) and he should be able to hook me up, right?
wahoofan 07-25-2005 07:54 AM
Looks like thishttp://forums.pelicanparts.com/uploa...1122306888.jpg
wahoofan 07-25-2005 06:07 PM
Anyone know the Pelican part no. for this vr?
pwd72s 07-25-2005 06:37 PM
Aye, here's the rub: "They don't make 'em like that anymore." Maybe Warren can explain their innards a bit better, but evidently they can be adjusted for output somehow, and their points can be cleaned up, made to function again? There is also the used market...wrecked-em yards, parts for sale ads, ect...then you can send 'em off for a check-out refurbishment. I carry a few spares with me, thanks to suggestions made by Warren here. 1.. Spare Bosch CD unit, 2..spare V. Regulator, 3..spare coil. None of these easily found in small town USA, so it's good to have them...(edit) Frankly, just looking at the pic, which is no measure of function of course, your V. regulator looks pretty good. Have you plugged in a voltmeter, done any read-outs as you're driving? A cheapskate test gauge is a cheap multitester hooked to a male cigarette lighter plug...lay the unit on your seat or have a co-pilot give voltage readings as you drive...
Lorenfb 07-25-2005 07:36 PM
"Even if you got it to work (which it might), that is not correct." - Zeke -
Not true!
A regulator is a regulator is a regulator. Any regulator when connected properly
will function correctly. Just ask Derrick/Dieter @ Lomita 911 they'll confirm this,
as I've used many alternates for them. The key point is that the SEV Marchel
has a high failure rate with large capacity batteries AND regulators which set
the voltage to greater than 13.75 to 14.00.
The SEV Marchel 55 amp alternators (early ones with the red plates) are badly
designed with an additional output diode causing a higher internal voltage
resulting in additional power losses (internal heat). Typical power losses
at 50 amps:
Early with red plate - 50 X 3 x (~1.0 volt diode drop) = 150 watts
Late without red plate - 50 x 2 X(~1.0 volt diode drop) = 100 watts
Obviously, these losses exclude the stator winding losses which are significant.
An additional problem with this alternator design is the way the diodes are
pressed into the diode plates. Because of thermo mismatch of the steel
header of the diodes and the aluminum plates, the contact resistance increases
(diode to diode plate) with the greater expansion in the aluminum plates versus
the diode header. The 928 SEV Marchel 85 amp alternators had high failure rates
because of the same design flaw.
The SEV Marchel regulator is very reliable and can be easily adjusted to prevent excessive
currents on the old SEV Marchel 55 amp alternator. Max voltage @ battery S/B less than 13.75.
wahoofan 07-26-2005 04:27 AM
A little confused here - does this mean I can't replace my vr without doing the alternator, too? The sticker on my car specifically states that the alternator and regulator must be of the same manufacturer.
My only real symptom here is a crazy tach. I just wanted to go after the vr because it seemed a likely culprit and a cheap part to switch out.
bigchillcar 07-26-2005 07:43 AM
dirty or worn ignition points will cause an erratic, jumpy tach as well..
ryan
pwd72s 07-26-2005 08:41 AM
Wahoo? I'd definitely say you need to do, or have done, some diagnostic work before you start to replace parts willy nilly...ryan made a good suggestion on the bouncy tach. Also, read my post on a voltage check.
cmcfaul 07-26-2005 10:56 AM
My radar detector flashes and beeps HI VOlTAGE on my 73 911 e until the car is warmed up (battery charged I assume) or I turn the lights on. It is very annoying. I have offten thought of replacing the voltage regulator but is it normal for the early 911's to have higher voltage outputs then today's cars?
Chris 73 911 E
Bell Rador detector (new)
tobluforu 07-26-2005 01:20 PM
Your reg, like my reg should look like what warren posted. I bought a new one from pelican which in now covered in white plastic instead of metal.
jclotz 07-26-2005 02:29 PM
Just recently replaced the regulator on my 72T. I had bought one of those volt meters that plugs into the lighter. Was getting voltages as high as 16 V at freeway speeds and also noticed my batteries would tend to overflow fluid. Replaced with one bought on-line (black plastic). Went in easily and now voltage stays in the 12.0-13.5 range. Have noticed that on occasion just after starting, the voltage will be a bit low, 11.5, and I will have to rev it a couple of times to wake things up. This didn't happen with the original regulator.
bigchillcar 07-26-2005 02:40 PM
clotz,
where did you get the meter and how much did you pay? is it an instantaneous digital readout?
ryan
jclotz 07-26-2005 02:49 PM
I purchased the 'Road Pro 12 Volt LCD Voltmeter' for $12 from S. King company
www.skingcompany.com/detail.asp?product_ID=1044
Gives a continuous reading. Was the cheapest I could find and seems to work OK.
1972_911T 07-26-2005 03:05 PM
How can you identify if you have the alternator with and inbuilt VR. When I got my car it had no voltage regulator I have just assumed it has the VR integrated alternator, also one of the wires to the alternator has been cut I read somewhere that this is done when upgrading to a integrated alternator? The alternator is a Valo. What symptoms would running a car with no VR cause?
bigchillcar 07-26-2005 03:49 PM
steve,
i don't think you could actually get away without having some sort of regulation. an alternator puts out wayyyy more than 14 volts without one and would quickly fry your entire electrical system. the regulator 'regulates' it's output down to 14 where the system voltage is designed to be.
ryan
wahoofan 07-26-2005 07:38 PM
So then this one from pelican should work on my car??
Voltage Regulator, 55A Bosch Alternator, 911 (1969-73), Each
A-603-206-02
pwd72s 07-26-2005 09:46 PM
A-603-206-02
It should work. It just won't look original. If you're sure your stock one is the problem, are you willing to sell it to me? I'd like to play with one a bit... I'll give you $10, you pay 1st class postage...
