No Power to the windows
I am having problems identifying the reason I don't t have power to my power windows. I Checked the door pigtail, driver side. Checked operation of the Power Window Control Unit behind the fuel gage (at least I think this is the power control unit), fuse is good as well. arg....
Check the wiring at the fuse panel for corrosion, and make sure the screw is tight. My windows worked intermittently until I figured that one out.
Fuse make look good but still not allow current.
Yes
It was the power window relay behind the fuel gage.
| All times are GMT -8. The time now is 12:00 PM. |
