-   -   Urgent Need Help! Shift tube bushing bracket mounting (http://forums.pelicanparts.com/porsche-911-technical-forum/231389-urgent-need-help-shift-tube-bushing-bracket-mounting.html)
VaSteve 07-16-2005 09:21 AM
Is this supposed to install like I have it in the photo, or under the tunnel lip. When I took it apart it was loose on the shift tube so i dodn't take note.
tkanks!!!
VaSteve 07-16-2005 09:23 AM
wrong photo...
http://forums.pelicanparts.com/uploa...1121531008.jpg
wevoid 07-16-2005 09:58 AM
It should sit on top - as you have it in the photo.
Regards
Hayden
porschenut 07-16-2005 10:06 AM
In my Carrera, it goes UNDER, not on top. I can't imagine the SC was different.
VaSteve 07-16-2005 10:51 AM
Problem solved. It goes on top. There is a notch in the housing. You can kind of make it out in my photo above.
(I had it in there under the first time, and it bound up. )
Wayne's a liar, this wasn't a 2 wrench job. :mad: ;)
