-   -   Manual Window Crank (http://forums.pelicanparts.com/porsche-911-technical-forum/231427-manual-window-crank.html)
PorscheGuy79 07-16-2005 12:55 PM
Manual Window Crank
So I broke my knob off of my manual crank windows... :rolleyes: I believe you have to replace the whole crank. Is it a simple unscrew the old one job or do you have to take the door panel off?
JAPPY 07-16-2005 02:29 PM
all you have to do is remove the plastic cover & there is is a screw that holds the winder on. un screw that & it's done. (assuming they didn't change the winder in 8 years!)
PorscheGuy79 07-16-2005 08:23 PM
Thats what I was asking. Thanks!
Early_S_Man 07-17-2005 06:29 AM
Matthew,
Driver's doors, right? Immediate fix ... remove passenger crank and put it on driver's side!
There are several options for replacing the brken knob ... short of just ordering another $30 crank ...
Replacement Knob, 911 (1974-79) PEL-911-WRK-01 $14.80
PorscheGuy79 07-17-2005 04:27 PM
Originally posted by Early_S_Man
Matthew,
Wow I shoulda thought of that!
Fyi, electrical tape works well as a temporary. :D
