-   -   Finally done with 2.0S rebuild, but won't rev past 4K!! (http://forums.pelicanparts.com/porsche-911-technical-forum/231439-finally-done-2-0s-rebuild-but-wont-rev-past-4k.html)
RetroSC 07-18-2005 08:10 PM
Yep, we're good on the venturies. Still not sure if I should have the long "booster" style one's in there or not. Anybody know about those?
911pcars 07-18-2005 11:31 PM
IMO, the booster venturis, unless they're clogged, are a non-factor in regards to your symptoms. They're more sensitive to airflow and allow fuel to discharge into the throat at lower air speed (or venturi vacuum) for more even, part-throttle fuel distribution
Bad pump or FPR, clogged filter, stuck advance weights, misadjusted throttle linkage, faulty rev-limiting rotor, faulty CD unit were all possible culprits as was your good-bad-good coil.
I hope all is well now.
Sherwood
RetroSC 07-19-2005 06:09 AM
Good to know on those venturies, I just thought they looked cool and wanted to see how they worked... good reasoning huh?!
I'll see how things go with a road test tonight though.
