-   -   Should I change my color (http://forums.pelicanparts.com/porsche-911-technical-forum/231441-should-i-change-my-color.html)
steven polaski 07-16-2005 03:26 PM
I recieved a call from my paint shop he told me since the car is completely stripped I could paint the car any color I wanted. It is know black what do you think ? I would like to paint it yellow ( yellow ruf ) or I like that metallic blue I've seen on a 930's before. Should I keep it black.
dean 07-16-2005 05:04 PM
I like black for several reasons. I would have a hard time deciding on an other color. Except Aubergine maybe.
Black is classic.
Black is less visible to the fuzz.
Good luck on your decision
Dean
porschenut 07-16-2005 05:10 PM
I have a black Carrera and it looks fabulous when clean, but that's the problem. Washing it becomes an obsession. That said, if I were in your position I wouldn't change the color.
On the other hand, aubergine would look really good, as would any of the metallic blues. I don't care for yellow, and I'm sick of Guards Red. I would probably go with #937 silver, which is period correct for your car and mine. It probably looks better than any other color on a 911, especially the mid-80's cars, and looks clean even when dirty. And it goes with any color interior.
cgarr 07-16-2005 05:21 PM
All solid colors are single stage, easy to repair too especially black, but dark colors show up any body problems, Metallics will be clear coated, thats good but harder to repair in the future. What is the interior color? You could go with an old 60's classic color like Polo Red!! I dont know what your shop does but I always tint the primer color to closely match the finish, this helps hide those stone chips.
Craig
mark 74 carrera 07-16-2005 05:28 PM
Many people look only for Black 911s. Leave it Black...very classic as stated previously
klaucke 07-16-2005 05:41 PM
When you say "completely stripped," does that mean everything, so that the front luggage compartment, door jambs, under the gas flap, in the engine bay, etc will all get painted? If that's the case (that is, where the color change will be completely invisible w/o checking the #'s or cardex), then I'd say a color change is a viable option.
However, if this is only a "glass-out" type job where the front luggage compartment, smugglers box, etc will not be changed, then I would stick with black. Especially where you have a 930, which command a premium and people want a black Turbo, the originality will help. And, it does look very classy on a widebody.
DavidI 07-16-2005 05:53 PM
Black..............no question about it.
randywebb 07-16-2005 06:47 PM
highly metallic black with a lot of big metal-flake in it....
kycarguy 935 07-16-2005 07:48 PM
Keep it black. Im one of those guys that look for black cars also. I have 6 black cars and they are alot of work to keep clean but worth it. Black is timeless.
aigel 07-16-2005 11:08 PM
I would go Bluetengelb, Ruf yellow. Yellow hides any imperfection much better, most of all dust and dirt. A yellow car will look clean and shiny for weeks, when you would have washed the black car half a dozen times. You have to like it. I certainly like flashy colors. Viper green? ;)
George
ianc 07-16-2005 11:40 PM
If everything is out and you are doing Jambs, engine compartment and front trunk, I'd go for silver. It really is the classic Porsche color.
I went for Indischrot on my car because I got a fairly good deal, but if I had to do it again, it would be nothing but silver.
Black is just too damn hot in the summer...
ianc
stv951 07-17-2005 05:54 AM
I would try Black NON metallic. The shine is amazing its a PITA tokeep clea and spotless, but its worth it I believe
GaryR 07-17-2005 07:21 AM
Black .. with lots of clear...
porschenut 07-17-2005 08:03 AM
Originally posted by SoCal911SC
I don't think many modern body shops would shoot this car in a non-clearcoat, regardless of the color (metallic or non-metallic).
Why not?
cgarr 07-17-2005 09:01 AM
Originally posted by porschenut
Why not?
Because they make more money using clears?? Whats nice about black for the DIY its a factory pack color, no mixing, off the shelf and cheap. I dont think the paint shops will cut you a deal because the paint is cheap but then most their cost is in labor anyhow.
Craig
Jim Richards 07-17-2005 09:04 AM
Normally I would recommend some funky early car color, but for your 930, I think it would be great in a fresh coat of the original black.
darkbeer 07-17-2005 10:02 AM
I'd go with Grand Prix White...if it's good enough for Michael Jackson, It's good enough for your 911...
SandyI 07-17-2005 10:22 AM
I'd go with speed/Ruf yellow over black.
Sorry but black and guards red are just too common in So Cal.
Kevin Stewart 07-17-2005 12:01 PM
Speed Yellow, enough said, Kevinhttp://forums.pelicanparts.com/uploa...1121626848.jpg
steven polaski 07-17-2005 01:09 PM
I think I will keep it black I could'nt live with my self knowing it was not the original color. The shop is using lots of clear they said it cost like $ 180.00 a quart. Some new kind of stuff they saw on some show car.
