c/ clockwise?
Does the firing order on my distributor cap go counter clockwise?
I have them running clockwise and it runs like crap. I've rechecked the wires about a dozen times. made sure all the wires click on the plugs ect,ect,ect. If this is the case, I waisted about two hours last night....... I thought for sure that my distributor went clockwise when I turned over the motor clockwise. |
Ron,
Put it in a forward gear (like 4th or 5th) take off the dist cap, push the car forward a little, and you see which way the rotor turns. You won't have to memorize that it turns clockwise. Rex |
Yes the SC has a different geared dizzy and spins the opposite way to virtually every other engine series...
Well that explains that.........
I'll switch them around tonight and cross my fingers. now on to my next problem. |
Now that we solved that, let's hope that a DAPO didn't screw up the dizzy indexing, I've seen em where the #1 mark was 180 out ;)
| All times are GMT -8. The time now is 09:14 AM. |
