mschuep's Avatar
Red face Running hot after Valve Adjustment
Just adjusted the valves, took the car for a quick spin last night and everything seemed fine. Heard a knock every once in a while, I figured I misadjusted a sticky valve. Decided to take the car to work so I could get the oil hot on the way home so I could drain today, and adjust again tomorrow.
On the way to work the battery light came on, and the car got continually hotter. When I arrived I was way too close to the red for my liking. Car was smoking quite a bit, but I think a lot of that was from oil/grime I probably got on the muffler, etc. when adjusting the valves.
Anything I could have screwed up in there relating to the battery/engine heat regulation? Would a valve being too loose cause something like this to happen? Usually the car runs at about 7-8 oclock, today I was around 10 oclock.
Thanks for your help guys
-Matt
-Matt
1985 Targa
Old 07-19-2005, 05:29 AM
David's Avatar
If your valves are too tight they won't cool correctly. The valves dissipate heat into the valve seats.
Old 07-19-2005, 05:38 AM
mschuep's Avatar
How easily should the feeler gauge slide in and out when adjusting?
-Matt
1985 Targa
Old 07-19-2005, 05:41 AM
one of gods prototypes
bell's Avatar
if the battery came on then that may be a different problem, check your fan belt, it may be slipping or worse yet not spinning the fan.
Brought to you by Carl's Jr.
Old 07-19-2005, 05:53 AM
mschuep's Avatar
Good call bell. The belt is, shall we say, bent out of shape. Hopefully I can get it back to where it is spinning the fan so I can get it 20 miles home, naturally the factory kit with spare belt is in my garage.
-Matt
1985 Targa
Old 07-19-2005, 06:11 AM
bell's Avatar
did you make it home? you NEVER want to drive an air-cooled 911 without the fan spinning, this can destroy an engine if it isn't caught in time.
and oh yea....welcome to the board
Old 07-19-2005, 04:17 PM
