intermittent starting problem =(
*sigh*.. my car has an intermittent problem, where you turn the key to start, and all you hear is the solenoid click, and the fuel pump... i turn back to off, and try again. Usually it starts on the second try, but today for the first time ever, i had to try many times. I rolled the car a bit will in gear to turn the motor over a bit, and it started on the first atttempt.
Is it my starter motor? could it be a bad ground connection?
_____________________
'73 RSR Interpretation
Old 07-27-2005, 08:23 AM
Designer King
Paulporsche's Avatar
Could be the motor, the solenoid or the ground. It's possible it's the flywheel, but I'd check the others first.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-27-2005, 08:39 AM
but since i hear the solenoid click, doesn't that mean its fine?
Old 07-27-2005, 08:45 AM
Designer King
No, sometimes the drive does not engage the flywheel. It can get balked by hardened , old grease and can be cleaned and relubed. In my car, w/ 170000 mi, I decided to put in a new high torque one.
Paul
Old 07-27-2005, 08:54 AM
DW SD's Avatar
Clean your ground and battery connections. connections at the chassis ground to starter should be cleaned, also.
I was measuring voltage at the starter when an assistant turned the key (when I was experiencing a similar problem). I realized that the voltage dropped to 1.5 V at the large positive terminal on the solenoid with a strong battery. The ground strap (chassis to starter or bellhousing) was completely corroded and not capable of properly carrying current. I bought a new one, cleaned the connections and everything has been 100% since.
Hope that helps.
Doug
1971 RSR - interpretation
Old 07-27-2005, 10:03 AM
