vizail's Avatar
Sandblasting Protective Coat
Just getting ready to sandblast the Engine Cooling Fan Housing etc. etc. I'll like to give the aluminum components a Clear Flat Solvent and Heat Resistant coat.
Some sugestions and Brands?
Vic
Old 04-26-2005, 03:38 PM
vizail's Avatar
NO REPLY
Vic
Old 04-26-2005, 05:11 PM
I've cleared sandblasted parts with VHT high-temp clear. Years later still looks good.
Warren & Ron, may you rest in Peace.
Old 04-27-2005, 10:54 AM
What hi temp clear coat did you use. I'm bead blasting parts now and want to clear coat them.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 07-19-2005, 06:40 PM
vizail's Avatar
Yes ..,It will be real nice to know wich brand or maker..
Vic
Old 07-20-2005, 05:01 AM
VHT is the brand. They produce hi-temp coatings (engine/exhaust) that are usually found at auto parts stores.
Old 07-20-2005, 06:04 AM
