Speedo slow indicating real speed
NHS repaired the odometer last winter; speedo worked good.
Now the speed indicator comes up too slow to the actual speed; doesn't indicate after 80m/ph. Any thoughts? :confused: |
wrong size tires?
What have tires to do with a speedo not indicating any speed after 80m/ph?
Obviously sticking somewhere. If you do not feel comfortable with taking the speedo apart yourself, try sending it back and see if they will give you a discount on the repair.
I assumed he meant INCORRECT speed. Is he saying the speedometer just drops to zero at 80? |
| All times are GMT -8. The time now is 04:50 PM. |
