930 and 915 gearbox id
Ill be looking at a 930 4 speed box and a 915 box tomorrow, has anyone got the codes for these boxes? any big giveaways if there are no numbers?
thanks blokes
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Just lift them.
I can carry a 915 box around my garage. I can barly lift my 930 box on to a 4" high cart. EDIT: this was meant to be funny (but still true), I'm sure someone has the part numbers.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 07-28-2005 at 04:12 AM.. |
still worth knowing Dave!
can anyone else help?
What do you want to know? Difference is quite obvious. 930 is physically larger...
this is 915: ![]() this is 930: left diff plate is 915, right one 930.
Thank you for your time, Last edited by beepbeep; 07-28-2005 at 02:06 AM.. |
cheers Goran, LOTS BIGGER THEN!! how about the codes for the 930 box? does anyone have a code for the 930 box?
What do you mean "code"?
Differential plate says "930" and has extra reinforcement ring, it's quite impossible to mix it up with 915 gearbox. There are only two types of 930 gearboxes, one with long clutch bellhouse (78-88) and one with short clutch bellhouse (75-77). Picture above shows transmission with long bellhousing, they are most common. Short bellhousing tranny is identical but has shorter bellhousing (sic). Short transmissions are more sought after beacuse they fit in 911 SC withouth modifying engine mounts. Long tranny requres rear engine mounts to be moved further back or clutch housing to be cut or front firewall/tranny mounts to be modified. They are quite rare (being made 75 to 77) and thus more expensive. Gears inside are exactly the same. You can easily check for presence of LSD by rotating the CV-flange...if other flange rotates in opposite direction, there is no LSD.
Thank you for your time, |
cheers Goran, I was wondering if there was a code for the turbo box. i think the 915 has a code on a flat tab at the bottom of the box which reads something like 915/60 or something like that. just wondered if you knew the code for the turbo...
got the boxes!! ive had a right result! one 915 box in good shape and one long bellhousing non lsd 930 4 speed for £700! im over the moon!
If you swap 915 tranny for 930, do you have to change any parts to make your speedometer work right?
I'm in heaven, when I drive my nine eleven... |
hmm, not sure, i reckon Goran knows though!
