MIK911's Avatar
Ignition wire SEPARATORS--need source
I will be upgrading to Magnecore 8.5mm wires soon. Instead of drilling out old wire separators to accomodate the thicker diameter Magnecores, anyone know of a source for new separators?
thanks
mike
'86 coupe
Old 07-21-2005, 12:55 PM
Slant930's Avatar
I think alot of people get ones from Jegs or Summit or some other muscle car parts catalog.
Tim
1983 930 w/ goodies
Old 07-21-2005, 01:40 PM
Virginia Rocks!
VaSteve's Avatar
I actually too the rubber ones that came with the stock wires and cut it with a razor blade to slip the old ones out and the new ones in.
Cost $0 and they fit back into the holes on the shroud.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 07-21-2005, 01:48 PM
Friend of Warren
Just as easy to drill out the OEM separators and they bolt right back into position.
Kurt V
Old 07-21-2005, 02:33 PM
MIK911's Avatar
How are the OEM separators attached to the stock wires? Does one need to remove the wires off the car, slip off the caps on end of wires then slip off separator?
Aren't the separators from SC rubber (therefore slice-able with razor blade), compared to harder plastic of 3.2 Carrera?
thanks
mike
3.2 coupe
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 07-21-2005, 11:00 PM
bigchillcar's Avatar
i don't have separators period. does pelican supply them? where are they found?
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 07-21-2005, 11:14 PM
