Poll: Which cam fits my needs best?
Poll Options
Wer bremst verliert
JohnJL's Avatar
Vote your Cam Choice
Specifics:
3.0L
9.5 CR JE Pistons
38mm intake ports
Single plug
Megasquirt II ITB on EDIS crankfire
7000 redline
Track car only
Lookin for broad torque range 3000 - 6500
Real-world experiences and dyno chartt welcomed!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-20-2005, 08:42 PM
Wer bremst verliert
JohnJL's Avatar
just voted 'other' myself as the poll isn't showing up in the forum...
Old 07-20-2005, 09:29 PM
PRO Motorsports
Tyson Schmidt's Avatar
Mod-S.
Same specs as early S, but the lobe centers are widened for a broader torque curve. It's an awesome grind, and fits the bill perfectly, judging by what you stated.
The engine responds nicely right off idle, and makes power from 3000 all the way to 7000.
We used them in a 3.0 with 9.5/1 JE's, 40mm intake ports, 40 IDA Webers, 1 3/4" headers, and a dual out early sport muffler. Dyno'd @ 205 at the rear wheels.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 07-20-2005, 09:45 PM
Wer bremst verliert
JohnJL's Avatar
Thanks to all you who voted. Need to place the order when the sun rises (5PM NYC time Thursday). Explanations of your votes are very much appreciated.
john
Old 07-21-2005, 05:56 AM
3 restos WIP = psycho
kenikh's Avatar
Talk to Camgrinder on this forum. He knows all things cam.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-21-2005, 08:15 AM
randywebb's Avatar
Yes - talk to some experts - tell them your goals re type of driving and some info about other things done to the engine.
A general poll just gives you votes for what most people have heard about, or would like to have in some unrealistic world where hp is free, and all the engines are above average...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-21-2005, 10:59 AM
pwd72s's Avatar
Uh Randy, I'd say that Tyson more than qualifies as an expert...
Old 07-21-2005, 11:16 AM
I would rather be driving
jpnovak's Avatar
I am building a similar engine and will use a Mod-S cam. Mine will differ by being a 9.8:1 3.2SS with twin plug (bore required). I am hoping for 260, which is about what you would expect from just the displacement increase when compared to the motor Tyson described.
You could go to a hotter cam but that would shift the torque curve to a higher rpm band. This would then need to port the heads to get intake velocities low enough at high rpm. You would also have to realistically mod the valve train to be reliable at 8K rpm where the motor wants to make power.
Old 07-21-2005, 11:43 AM
randywebb's Avatar
So would I -- but what I said is the 'poll' -- right?
Old 07-21-2005, 12:00 PM
camgrinder's Avatar
The mod-s (DC40) on 108 degree or wider lobe centers would work nicely. It will give up some power to the 964 or super cup cams below 4000 rpms, but you will have no problem making hp at 7000 rpms.
John Dougherty
Dougherty Racing Cams
Old 07-21-2005, 01:08 PM
Wer bremst verliert
JohnJL's Avatar
Thanks Tyson and jp
Hi John.
Yes, I trust John. In fact he already has my cores and rockers!
I wanted to hear from a few others with similar setups and maybe see some torque/power curves for the options I have been discussing with John.
thanks all!
Old 07-21-2005, 01:45 PM
