915 transmission helper
Years ago, when I was a struggling punker, I had a job as a mechanic at a gas station. The old boss man suggested that I use some STP in my 1954 ford manual transmission to help it go through the gears a little better. I just got through doing that to my present 915 tranny. I seems to have helped in the smoothness of the gear changes. STP even suggests its use in the transmission at a 5% ratio. Can't assume that it will do the trick for all our problems but, I can tell you that it has made a difference in mine. Looks to me like I have found an alternative to swepco for now.
The older I get, the more I realize that patience is a virtue and, I only wish that I had some.
Old 07-20-2005, 04:54 PM
Geary's Avatar
STP breaks down pretty quickly during pressure/heat tests. OK for assembly, I guess.
Old 07-21-2005, 10:08 AM
