bcheney's Avatar
powder coating
I live in Orlando FL and I am looking for someone to powder coat my fan housing and fan. I have a 1989 911 3.2. The fan is a factory piece and the housing is a new aluminum repro from Vertex out of Miami. Does anyone know of someone in my area that can do the job? Or, do you know someone I can ship to that would do a good job? What should it cost to have this work done?
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 08-01-2005, 07:11 PM
Licensed User
Shuie's Avatar
Im in the same boat. Except I have an entire engine tin and a fan and housing that need to be done. There is no one who can do powdercoat here. So who can I ship this stuff to?
Old 08-01-2005, 07:13 PM
randywebb's Avatar
There are some paints you can use - they all match better than powdercoat. And there is a Glasurit that is very tough and matches well.
Hard to believe nobody in "Boss Rouge" can do p/c...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-01-2005, 09:46 PM
lateapex911's Avatar
Get the kit and do it yourself!
There is nearly any color you need available..
I did my front end parts, here's a shot of my Koni red strut tubes:
Used rear Koni on the left, new original in the center, and new powder coated strut housing on the right.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 08-01-2005, 10:11 PM
MBruns for President
JeremyD's Avatar
Just had some powder coating done here -
D & C Powder Coating
911 Woodrow Wilson St S, Plant City, FL 33563
(813) 719-3440
Top notch very reasonable... I'd highly recommend
I'd call them first - just to make sure they will take a shipment.
I did all the engine tin too = he even welded a crack - bead blasted - was about $300.
Old 08-01-2005, 10:18 PM
JeremyD's Avatar
woops - picture attached...
Old 08-01-2005, 10:20 PM
Here's the actual tubes after powdering and just before baking in the "oven".
The holes are filled with plugs,and the spindle wrapped with special heat resistant tape.
Old 08-01-2005, 10:24 PM
Or, for that money, send it to him!! LOL....
Old 08-01-2005, 10:31 PM
Registered abUser
TerryH's Avatar
Al Reed
'81 911SC Coupe SOLD
Old 08-01-2005, 10:56 PM
Jake, any details on that oven? I've got the kit, but still no oven. Is it constructed of wood and lined with a foil insulation? Is that a heat lamp and how hot do you bake the parts? Thanks
Chris
'80 SC
Old 08-02-2005, 12:14 AM
The details are so low tech it's almost embarrassing, LOL!
The oven is nothing more than the foil faced foam screwed and taped together, and propped up on two 5 gallon buckets.
I then cut a hole in the lower back to clear the propane heater, (2 burner) Te dor slips into teh opening, and has a small hole cut for inspection.
I followed the directions and pre heated the part before spraying the powder. The heaters were set to their lowest setting, and the oven reached just under 400 degrees.
I used an IR type pyromter, and pointed it at the various items. IT was critical to the whole affair.
easy stuff, but a bit time consuming!
Old 08-02-2005, 12:40 AM
87coupe's Avatar
Got a link to one of these DIY powder coat kits?
ßrandon
Old 08-02-2005, 12:50 AM
K9Torro's Avatar
Hey guy's -
I do my own PC on small stuff, I use an old house type kitchen stove/oven for my " baking " , it will do anything that you can put in it and also makes coffee/lunch in my shop...
Two of the best places to do your shopping is at :
www.caswellplating.com
www.eastwoodco.com
They both sell " kit's " as well as the supplies , both around $200 for the whole set up with the small compressor or you can get just the gun for around $100
Also HarborFreight sells a kit for a similar price,
The best thing to do is build you a small recovery both, to save on the powder but you have to take care not to mix or contaminate if you reuse it.
It is also best to bead or sand blast the parts, I got my blaster from HarborFreight years ago and it is still going strong,
Hope this helps,
Todd
PS... to the guy in FLA I have a company that I use in Jacksonville to do large items that will not fit in my oven , they are a little expensive but do a very good job, a DSA roll bar cost me $125 from bare metal.
Old 08-02-2005, 02:45 AM
Seeeu911's Avatar
Re: powder coating
bcheney, A company in Orlando on Old Winter Garden Road called Powder Tech.
Ask for Don. What is cool about these guys is if they are doing other parts the same color as yours they really reduce your cost. They do mostly industrial/race car stuff and have lots going all the time. They often do small motorcycle pieces for me at very reasonable cost, especially if they are running that same color. They prep very well and nothing they have ever done for me is less than perfect.
Old 08-02-2005, 03:31 AM
JeremyD's Avatar
Originally posted by TerryH
Al Reed
Normally I would say yes - but I have heard, and experienced (BBS wheels) a 3 month wait getting things from Al. Love his work - love his prices - but he has become a victim of his own success.
Powdercoating is pretty much a no brainer - except when it comes to magnesium. It needs to be heated after bead blasted to allow for outgassing - if you don;t you get lots of little bubbles in the paint.
Old 08-02-2005, 06:05 AM
Columbia Coatings sold me mu kit, and there is a killer place in PA that has hundreds of colors and will send a great sample chart for the trickier colors.
Here is Columbia...not the best web site to navigate, but the gun was cheap and functioned ok.
http://www.columbiacoatings.com/main.htm
Old 08-02-2005, 05:18 PM
bcheney's Avatar
Thanks for all the info. I am going to check with the local Florida guys mentioned. Will post results.
08 Cayenne V6
75 914-6 Conversion
Old 08-02-2005, 07:24 PM
