1972_911T's Avatar
924 Seats
I'm looking to upgrade my worn out 1972 911 seats and have seen some nice 924 seats for sale, these look very similar to some a friend of mine had in his 77 911 targa. What I want to know is what modifications if any would I need to make the 924 seats fit in an early 911? The guy told me his runners were 37cm apart whereas mine are 43cm apart can the runners be moved out?
Thanks Steve
Old 07-22-2005, 04:07 AM
Double Trouble
targa911S's Avatar
Adapters should do it. Hell you can make them ..I did. Flat stock 1/4 or 1/8 x1.75 at Home Depot. You will have to have a trailer shop or someone make seat belt "ears" and weld them on to the new rails if your belt receptors are mounted on your old seats. I converted my 70 to 74 seats that way.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 07-22-2005, 05:12 AM
1972_911T's Avatar
Hi thanks for the responce! did you put the adapters on the outside nr the door or in the inside nr the handbrake or both?
Old 07-22-2005, 05:50 AM
Double Trouble
targa911S's Avatar
One on each side to keep the seat centered, and level side to side. You CAN buy them (do a search on seat conversion) but they are like $110.00 + per seat. I made mine for $8.00 in materials and $15 for the welding. Oh and welcome to the board on your second post!
75 914 1.8
2010 Cayenne base
Old 07-22-2005, 07:48 AM
1972_911T's Avatar
What about the locking mechanism that locks the runners for adjusting the seat position, dose this need to be modified?
Old 07-22-2005, 10:30 AM
Double Trouble
targa911S's Avatar
no ..it stays. it just bolts to the adapter instead of the floor.
75 914 1.8
2010 Cayenne base
Old 07-22-2005, 11:57 AM
1972_911T's Avatar
Do you have any pics of your modifications by any chance?
Thanks Steve
Old 07-22-2005, 12:11 PM
Mookster's Avatar
Install Boxster seats!
They are readily available and easy to install with minor drilling on the existing frame supports.
There are a couple of threads on how to do the install.
If it has a skirt or tires, it WILL cost you money!
Old 07-22-2005, 03:59 PM
Double Trouble
targa911S's Avatar
I could try. Not much to see as the seats cover most of it.
75 914 1.8
2010 Cayenne base
Old 07-22-2005, 04:39 PM
